Pressure Testing (Long Post)
Old Sep 17, 2010 | 09:05 AM
apexanimal's Avatar
^ ditto...
i was surprised by the rear bumper findings as well...
i'm still hoping to get a magnehelic gauge that can read 20-30" of water so i can distinctively test the drop in pressure with mods... we'll see
Old Sep 17, 2010 | 05:08 PM
Blue-Civic-Hybrid's Avatar
Well, I might have some access to some "scrap" aircraft grade sheets of aluminum. All I would have to do is really measure out the entire area beneath the rear and start cutting. I need to get a jigsaw soon!
My next question would be about that wonderful little triangle jacking brace in the rear of the GD3. It looks quite stout and heavy, have any thoughts on it's removal?
Old Sep 17, 2010 | 07:33 PM
apexanimal's Avatar
you could... i like having a central jacking point for the rear...
if it's welded on (not sure) you'd have to chisel it off... i don't think you're going to find much weight savings there however...
if you're going to do a diffuser, you can just cut an opening for the tow/jack point to come through... it won't affect the dynamics that much...
Old Nov 11, 2010 | 01:20 PM
Bman98SL2's Avatar
Nice to see another fan of the Autospeed site, and their interesting work eliminating "negative boost." Inspired by their results, I've acquired some magnahelic gauges as well.
Interested in the entire intake tract, I measured negative pressure at the throttle body with the stock intake, and with a flared piece of 2.5" stainless tube (basically a velocity stack). Not surprisingly, the intake showed far more negative pressure (restriction) than the velocity stack did. What was surprising was that if I removed the bottom half of the stock intake, I also removed most of the restriction. So, my plan at present is to duct from the existing duct in the lower driver's side corner and replace the lower half of the airbox. If I ever get to it, I'll post results.
Thanks for your interesting posts! For folks in the know, data actually matters.
Bman
Old Nov 11, 2010 | 01:44 PM
DiamondStarMonsters's Avatar
So, while I am looking for the data and associated math that I took on my car here is a post from a private tuning forum:
Originally Posted by 16g-95gsx
Logged through an AEM 3.5 bar map sensor, at 6000rpm and around 32psi of boost I am seeing around a 0.37-0.59psi pressure drop (varies due to slight voltage fluctuations). Pressure drop should be pretty linear with rpm as long as boost is kept constant and IAT doesnt increase too much, so you can imagine around 0.55-0.85psi of total pressure drop for that same 32psi at 8500-9000rpm. My air filter is a 9" length by 6" diameter unit on a custom 4" CAI intake that I made. 0.85psi would be a decent amount considering that I'm starting at only 13.7psia here in the mountains, but ultimately it is a PR difference of around .23 for my scenario.
http://www.ncdsm.com/16g-95gsx/Intak...e%20Coated.JPG
http://www.ncdsm.com/16g-95gsx/Engin...ft%20Angle.JPG
I would tend to say that this would be a pretty good representation of what some of the better CAI systems out there as it has about the equivalent bends, 4" diameter, and a pretty new K&N filter. If it were possible to entirely reduce that pressure drop down to 0, then I could see a decent power increase as this PR difference is about the equivalent of running 2-3psi more boost assuming IAT was kept constant. In reality it is impossible to reduce pressure drop to 0, and I would just consider this a part of the downsides that come with running an intake pipe at all. Realizing that I am located 2000ft asl, giving me an automatic 1psi ambient pressure loss, I lose more efficiency just to the fact of me being in the mountains than I do as a total dynamic loss through the intake pipe. When coupled together though you could easily see where being at sea level with no restriction at all into the compressor would net some pretty solid gains.
Here's another explaining the same thing:
I did a little pressure drop experiment. I run a very large new K&N cone filter (9.5" long & 6.6" dia) on a 2g turbo eclipse. This air filter has a flat area of about 168 sq inches, enough flow for 970 cfm or 650 h.p. I basically run a big K&N airfilter, HKS VPC, NO MAF, and a big 4" aluminum pipe tapering into a RRE 2.25" turbo inlet pipe. I used a Magnehelic Pressure Differential Gauge (0-100 inches of water) to measure the air filter pressure drop, ultra accurate. Measured at the little nipple right on the rubber MAF inlet hose. I figure my pressure drop should be next to nothing. My car was run on 20 psi and maybe kicking out 360 crank h.p., according to DSMLINK.
I was expecting maybe 4-6" of water pressure drop thru the huge K&N airfilter which is 1 week old. Boy was I in for a surprise. Light cruise there is no pressure drop, under WOT there is minimal until 4000 rpm then it hits 10" pressure drop. Max pressure drop is at 5000-7000 rpm at 24" of water on 20 psi boost pressure on a 45*F night. For you guys that don't know, 29" of water equals 1 psi.
This goes against every thing I've read, that the air filter has little to no pressure drop. I say bullshit. I'm thinking of running a 14" long cone filter instead. Basically I have .82 psi of pressure drop just thru the airfilter. After the pressure ratio rise in the turbo compressor this would be almost 2 psi lost after the turbo. You cannot go too big on an airfilter.
So basically smooth transitions and as few bends as possible. If you have to bend, bigger radius is better.
If you have a 2" throttle body and 2" MAF/MAS you want 2" piping. Bigger is not always better, except for the air filters you stick on the end of the 2" pipe that should be as large as is feasible to increase surface area, and decrease intake vacuum but maintain steady, high velocity laminar flow through the pipe.
Old Nov 11, 2010 | 02:05 PM
For more test data on flow, pressure etc. Check this out:
SDS EM-4: Aircraft
Here is a guy who took a turbocharged subaru power plant and put it in an aircraft, and has more data in his few pages than this entire forum.
Old Nov 11, 2010 | 06:16 PM
Originally Posted by apexanimal
^ ditto...
If you can find one, get a mercury filled gauge, on the face of it, it will look like lower resolution, but I find the added inertia from the mercury makes it read out more accurately. The blue-water ones seem to fluctuate too much, at least IMHO.
Old Nov 11, 2010 | 06:27 PM
So what you are trying to say there still might be a chance that a rear diffuser would net some aero gains? I'm just gathering materials first before I even start cutting everything to mock up anything in metal.
Currently, I'm getting some coroplast from the left over campaign signs from the election to mock up some lower triangular pieces for the rear of the Fit.
People look at me weird when i pick up the signs laughing hysterically...hehe
Old Nov 12, 2010 | 02:08 AM
Well there's theory and there's practice, and only one really matters in the end.
It might be worth while for the population that would use it as a function item! And if it looks good to boot, you've got that going for you.
Old Nov 12, 2010 | 12:21 PM
apexanimal's Avatar
Bman
good info...
i only got a sensitive gauge to test aerodynamics, and never got around to getting a wider range to test the intake system... just from seat of the pants the 2.5" 90* pipe i did from the airbox to tb made a huge difference... good to know there's more to be done!
Old Nov 12, 2010 | 12:57 PM
good info...
Do you happen to have any pics of this? I'd like to try this myself, if you could give my a little DIY, I'll try to mock one up myself.
Any updates for the front section of the bumper where the best place to route some tubing to "guide" the air into the airbox? Sorta like a ram air effect thing.
Old Nov 13, 2010 | 11:08 AM
  #32
apexanimal's Avatar
the only place i didn't test from is the fog light...
but so far from what i've seen, the upper grille area is going to be the best place so far... the most pressure is seen there...
no pics... i usually have my hands full trying to drive and look at the gauge at the same time and not hitting anything in the process...
Old Nov 15, 2010 | 08:10 AM
  #33
Bman98SL2's Avatar
I dug up the readings I took on my then-new Fit in late 2008:
Intake in front of the throttle plate:
-0.10” during hill descent
-0.35 – 0.55” during 65-70 mph cruise
-8.0” during WOT in 3rd at 6k rpm
-8.5” during WOT in 2nd at rev limiter (going up a hill)
-3.5” with the air filter removed and lid propped open (so lid and elbow) (also at WOT, under load)
Restriction at maximum air consumption (WOT and redline) is -3.5” with a 2.25” flared “velocity stack” attached directly to the throttle body
This suggests to me that the greatest gains are to be had before the air filter on the stock intake system. If the restriction of the airbox lid / elbow is the same as a flared "velocity stack," then I don't see much to be gained here. It would be interesting to see what numbers folks saw at the throttle body at WOT / redline with an aftermarket intake.
Bman
Old Nov 16, 2010 | 12:17 PM
  #34
apexanimal's Avatar
^ good info...
it would be interesting to see what gains/losses could be seen post tb between the stock tb, and a larger aftermarket tb...
those numbers also still make me think that if we pick up air in a higher pressure area it'll further help efficiency...
Old Dec 16, 2010 | 12:34 PM
  #35
Bman98SL2's Avatar
Come spring, I'll try to cobble together my intake idea that plumbs the upper part of the stock intake to a custom lower routed to the front of the car. I'll post whatever I find out.
Bman
Old Dec 16, 2010 | 05:20 PM
  #36
apexanimal's Avatar
^ good deal - thanks
Old Dec 16, 2010 | 07:22 PM
  #37
Thanks for the great info and the idea.
Old May 20, 2013 | 12:26 PM
  #38
TPColgett's Avatar
Ancient I know... but,Whoa... How did I miss this thread?!
I actually just completed a "fog light delete"... And have an AEM CAI that runs down to the inside of the drivers fender...
I kept the plastic outer housings on as they looked as if they would duct in air... Wonder where I could borrow a gauge...
Old May 21, 2013 | 08:10 PM
  #39
apexanimal's Avatar
If you were closer to me I'd let you borrow mine...
This is ideal, but the molding is beyond what am capable of/hav patience for:
https://www.fitfreak.net/forums/fit-...tml#post995871
This is what I have created so far:
Myxalplyx
Feb 23, 2016 04:32 PM
kurisux92
Aug 25, 2011 10:12 AM
drock305
Feb 18, 2010 09:11 PM
KnifeEdge_2K1
Apr 16, 2007 03:22 AM
