Has coil replacement fixed anyone's misfire/stutter?
Old Jan 16, 2013 | 10:50 AM
  #101
willy65000's Avatar
Are coil packs really only designed to last 50K?
Old Jan 16, 2013 | 05:39 PM
  #102
Carbuff2's Avatar
The COP coils on our Acura were still going strong at 180K miles/12 years.
The coils on our Fit are still OK after 80K miles/5 years.
Old Jan 16, 2013 | 08:45 PM
  #103
willy65000's Avatar
Mine are still good at 130k.
Old Jan 17, 2013 | 04:30 PM
  #104
yanz's Avatar
add me to the list!
just changed the 4 coils with 150$ ebay ones and they are working perfectly
car runs sooo smooth!
Old Jan 19, 2013 | 03:31 PM
  #105
mahout's Avatar
Originally Posted by yanz
add me to the list!
So who's the manufacturer? ebay's not enough info. ZAnd $150 perr?
Old Jan 20, 2013 | 01:28 AM
  #106
yanz's Avatar
Old Jan 20, 2013 | 10:16 AM
  #107
mahout's Avatar
Checking the seller, ACauto, reveals a very high customer satisfaction (more than 2000 submitted at 99%), but there's no indication if the coil packs are that good, just overall shipments.
However, I would not be surprised to find the manufacturer may be an OEM who is willing to sell at a price not much greater than OEM prices.
So until a couple of Fit owners go out on a limb and tries them we'll be as wary as this poster. But the next owner who comes here with ignition problems we may take a chance ...
My cohort got an answer on the low cost coil packs. They didn't identify the manufacturer but said it was an OEM supplier. Certainly $124 plus shipping certainly is a good possibility.
Old Jan 21, 2013 | 12:36 PM
  #108
mahout's Avatar
The SAE testing performance is good for 50,000 miles or equivalent. When Honda says 110,000 miles thats the tyopicallife from those tests. Like everything, there is a spread in the actual lidfe of devices. For coil packs the -3 sigma, or the earliestg coils start to show failues is about 40,000 miles but owners should expect to get a hundred thosand miles.
Now that the prices of coil packs are coming down to earth, like $125 for 4, the maintemnce of copil packs is beginning to get real with cusomers.
Old Jan 22, 2013 | 11:01 AM
  #109
Marrk's Avatar
^^Thanks, mahout.
Old Mar 4, 2013 | 02:05 PM
  #110
yanz's Avatar
2 months later my cheap ass ebay coils pack are still running fine!
Old Mar 4, 2013 | 02:07 PM
  #111
Marrk's Avatar
Canada, eh?
(j/k)
Old Mar 4, 2013 | 03:21 PM
  #112
yanz's Avatar
hummm yes, what's your point?
Old Mar 4, 2013 | 07:25 PM
  #113
Marrk's Avatar
^^No point. Just a poor attempt at a joke. Sorry.
Old Mar 5, 2013 | 12:55 PM
  #114
yanz's Avatar
:P
yeah from quebec canada, where coils pack for fit are 130$ each and where they take 50% of our pay check!
Can we switch
Old Mar 7, 2013 | 02:43 PM
  #115
ErinM's Avatar
[QUOTE=SilverBullet;1157135]Yes but they developed the ecu. There is no reason the coils cant last and if you use the right oil and fuel it will last at least to 100,000 miles. My dad has used Kendall oil and premium fuel in his car since day one and has no coil failures. The car is 16 years old and has over 100,000 miles with no coil problems and the engine is still like new.
Does ethanol content matter? It seems that I get better mileage with non-ethanol, but do you know if the coil packs last longer with ethanol or non-ethanol? Non-ethanol tends to come in premium where I live.
Old Mar 7, 2013 | 11:06 PM
  #116
SilverBullet's Avatar
[QUOTE=ErinM;1167193]
I think it does. The engineers use a high octane and pure fuel when they set up the motor and ecu. There is a difference in premium gas I know only 1 brand around here that does not use ethanol in their premium and that is what I use. Knock is what damages the coils and ethanol blends are not consistent but if you use premium with ethanol it resists knock better than regular.
Old Mar 8, 2013 | 01:28 AM
  #117
loudbang's Avatar
[QUOTE=SilverBullet;1167289]
Maybe you could TRY and explain how knock damages plugs when the Fit has a "knock sensor" that prevents knock (in most cases). Then try and tell us just how knock damages coil packs. It's not like they know what is going on in the combustion chamber and current flow is not magically effected by conditions other than resistance.
Old Mar 8, 2013 | 01:49 AM
  #118
doctordoom's Avatar
Supervillain
I've never put premium in my Fit and haven't had coilpack issues in >100k miles.
Save your money, use the cheapest gas, premium isn't required. The Fit's engine isn't going to knock on regular unleaded, if it did, the manufacturer would recommend higher octane.
Old Mar 8, 2013 | 10:44 AM
  #119
Marrk's Avatar
I never use premium in my Fit and I have had no coil pack problems. I'm at 82+k mi.
Old Mar 10, 2013 | 11:38 AM
  #120
A knock sensor retards the timing only after knock was detected and will retard the timing to all cylinders to prevent knock. There is oil jets that spray the pistons to cool it off and it sprays in the middle of the piston above the spark plug but there is a oil ring that forms over time which can cause a hot spot that cause pre ignition. Coils fail due to contamination and usually caused from knock that pressure escapes from the plug causing the coil to overheat and misfire. There is a lot of the variables that all play into knock and not just fuel. Cycle to cycle variables, oil blow by, to name a few.
Engine Basics: Detonation and Pre-Ignition by Allen W. Cline Thanks to Krimson_Cardnal for sharing this.
