spark plug gap - 2007 Fit - L15A
So, what is it?
1.1 mm = .043 in.
or
1.3 mm = .051 in.
The owner's manual for 2007 Fit calls for NGK or Denso 1.3 mm plugs, but so many owners are gapping their out-of-box NGKs and Densos to .043 in. There are dedicated spark plug change threads here at Fit Freaks claiming that .043 is proper. Is there any indisputable evidence that would indicate one gap or the other?
Seems the L12A and L13A engines call for the 1.1 mm (.043 in.) plugs.
Spark Plug Inspection (L12A/L13A)
But if that's the case, and if the owner's manuals for the Fits with L15 engines call for the 1.3 mm (.051 in.) plugs, then what gives? This should probably be cleared up.
1.1 mm = .043 in.
or
1.3 mm = .051 in.
Is this from the "manual" for the L12A and L13A, the service manual I linked to above?
Like I said, I've got an L15A, and my owner's manual calls for either NGKs or Densos pre-gapped at 1.3mm (part numbers ending in 13), not the ones pre-gapped at 1.1mm (part numbers ending in 11). See what I'm saying?
Not to mention, why would I purchase the 1.1 mm plugs when the owner's manual calls for the 1.3 mm plugs? Moreover, why would anyone buy the 1.3 mm plugs only to gap them down to 1.1 mm - when meanwhile, the owner's manual still calls for 1.3 mm plugs?
Again, there's spark plug change threads on here instructing people to use a gap between .043 and .044 in. I haven't seen one yet within this forum instructing owners of L15As to use what's specified in the owner's manual (.051 in. or 1.3 mm). It's confusing, and it needs to be cleared up.
For a stock L15A, what is it?
A 15% to 18% (approximately .2 mm) difference in gap not critical? Could you explain, please?
WHEW all changing the gap does or not does is making the flame kernel larger or smaller. That small variant still means there will be a spark to ignite the fuel mixture.
For PERFECTION one would need to vary the gap larger and larger until the combustion "blows out" (like a birthday candle) the flame kernel then drop back a minute bit.
For a stock fit or any car one would never notice a difference of 15-18% simple if you are this particular either go by YOUR owner manual or buy a set pre-gapped and put them in.
<100whp on a stock Fit can take a pretty fat gap without issues and is actually beneficial in some instances..
If I remember right, and it's been a long time and with older technology so please correct me if it no longer applies--
The gap increases with time, so the gap when new and the gap after 10,000 miles are a bit different. I don't know that it much mattered when we replaced plugs every 10,000, but now with 100,000 mile plugs do they still widen out with usage?
Because if that's the case might it make sense, if you're going to regap or replace more often, to start with a wider gap because Honda picked the gap based on average over 100,000 miles?
Kevin Evans
Sep 26, 2020 02:05 PM
Bryanfit
19
Mar 17, 2017 02:03 PM
wackyflik
Oct 4, 2014 09:11 AM
