09 sport shifting HARD, paddles not working
Old Nov 16, 2013 | 03:58 PM
floggindave's Avatar
I tried to search this before asking, but couldn't find what i was looking for exactly.
My wife's 09 fit (automatic, 63k miles) started having a problem the other day, where at 17-20mph (2nd-3rd?) it would shift HARD, like it was getting dumped into gear. Almost like letting off of a clutch suddenly. It was happening again from 4th to 5th on the highway. While this is happening, sport mode will not work. It does not do this every time the car runs. Some people have suggested turning the car off and then restarting it. I have heard it's possible that a solenoid is the issue, but some people claim that flushing the atf clears the problem up. If it were just the atf needing flushed, why wouldn't it be consistent throughout each run of the car? Any help would be appreciated, I am not overly knowledgeable about cars.
Old Nov 16, 2013 | 05:13 PM
Dean's Avatar
What I would do if it were me.
Check fluid level of transmission. Ensure the car is on a flat surface.
Taken from another FF post:
"for the fit its the following (from the 09 service manual):
start engine from cold (overnight). then wait until the fan kicks in twice (it'll take a bit and make sure your ac is off and the fan is set to without defrost.
once it kicks in twice, turn it off and wait 60 seconds after shutting off the engine, but not more than 90 seconds seconds to check the level. Any longer and the level may seem higher than it actually it.
After that checks out, I would unplug the (-) battery lead and let it sit 5-10mins then hook it back up in hopes it resets everything.
Old Nov 16, 2013 | 10:10 PM
well, the "D" on the dash started flashing and the engine light came on. error code P0756 for solenoid B. I really hope I can change this out myself.
Old Nov 17, 2013 | 02:25 AM
2010FitSport's Avatar
Before changing the solenoid you should do the tests for that code.
Solenoid codes may be a solenoid but also may be a wiring issue that controls the solenoid.
Old Nov 20, 2013 | 12:37 PM
Subie's Avatar
Not that hard. Been there, done that.
Here's some older related threads that might interest you:
https://www.fitfreak.net/forums/test...honda-fit.html
https://www.fitfreak.net/forums/1st-...-low-help.html
2007 Honda Fit Solenoid - 5DR SPORT KA 5AT ATM0710
Good luck!
Old May 13, 2025 | 12:11 PM
fitturismo's Avatar
What ended up happening? my 2012 started doing something similar...
BrianFantana
Jun 22, 2013 09:51 AM
andeano
Jan 27, 2013 12:18 PM
Shockwave199
Jan 12, 2010 11:06 AM
thetasigma1186
Oct 22, 2008 10:22 PM
cab0053
Aug 12, 2008 09:03 PM
