Windshieldwiper noise
Old Jul 1, 2012 | 01:04 AM
  #81
3bmbm3's Avatar
Reversing blade rocks !!
Yes it solves the noise problems, but I got one more question, when should the blade be replaced with new ? Can we only replace blade, not the whole arm combo ?
Where to buy the blade ???
thanks
Old Jul 1, 2012 | 07:44 AM
  #82
doctordoom's Avatar
Supervillain
Haha congratulations!
Replace whenever you feel the performance is no longer acceptable.
Yup, you can get the OEM blade inserts from Honda.
Old Jul 2, 2012 | 12:20 AM
  #83
3bmbm3's Avatar
Thanks fro reply.
I checked my wiper blades today, I found it is impossible to reverse, noticed 1 side labelled "lock", the other labelled "tip".
It is technically impossible to reverse it as you can't insert to slide it in if you reserve blade.
Please update me as I am lost.
Old Jul 2, 2012 | 04:15 AM
  #84
doctordoom's Avatar
Supervillain
I don't know, I never tried to reverse my wiper blades.
It sounded like you reversed yours and were excited about how great it worked.
Old Jul 2, 2012 | 07:42 AM
  #85
jeff618's Avatar
When you finally throw in the towel on the original wipers (because they will dry up from the sun and wear out), check out the trico neoforms which I'm still using. I use wipers123 online and they list exactly what is needed for front and rear.
dave92029
Nov 4, 2019 06:48 PM
cmdnmkhl
Apr 19, 2015 01:52 PM
pipcorona
Jul 16, 2014 06:10 AM
switchbrdopr
May 15, 2006 12:47 PM
