Plugs????
you only run colder plugs when your creating more power and want to help control detenation....if your boosted or on the bottle you usually go a couple steps colder do to the increased heat from the extra air/fuel in the cylinder...if your n/a and stock use stock heat range....if you n/a and high compression usually one or two steps colder depending on compression
yes the motor will run on colder plugs but colder plugs will never reach proper temperature for self cleaning
The threaded portion of the plug gives you the heat range, look at the threads you'll see that a few toward the tip are a dull burnt looking color the rest are black and shiny. You want about 2 threads showing the heat on the end of the plug and the rest of the threads to be shiny. If only one thread is dull the plug is too cold, and if you have three or more threads dull, theyr way too hot.
not bad. . . .but to get a more accurate reading of WOT, try going WOT as long as posible, shut it off and coast back. Then check the plugs. . . .its how we do it at the racetrack, ofcourse its only a secondary measure since we run wideband O2 reader and EGT
Im going to quote an advanced engine management book " modern engines are run at stoichiometry 14.68:1 a/f under most conditions to balance emissions and fuel economy. For best economy we sing to the other side of the stoichiometric balance about 15.5:1 a/f since fuel economy is targeted under cruise conditions. For best power it has been found that somewhere between 13.2 and 13.4:1 a/f is ideal"
Now if your running a turbo its a little diferent....whats your set up ??
