MT swap
MT swap
i know this topic came up already
but i cant find it
if you guys don't mind posting again ?
is it just as easy as swaping on EK or EG ?
does the ECU need to be change ?
thanks
but i cant find it
thanks
i think 1.3 ecu is different then 1.5 ecu
how about 1.5 at swap to mt ??
You still need the MT ECU. The cluster has to be change to get everything work. It is a lot of work to do from AT to MT. The tran. mount is different than MT, so the mount need to custom make to fit. So.....so..........so.............many custom work need to be done.
If I can go back I will not do the MT swap, I just keep it AT. Well, I enjoy the MT feel now...............hehehehe.
trinisir
Jun 25, 2014 08:58 AM
FELIXY69
Jul 29, 2009 10:15 AM
