Turbo GD : What clutch are you guys running?
~Robert
then there isnt any chadder.. i had a lightweight flywheel on a different car and it sounded like a helicopter at times. lol
~Robert
Do you have one on the Fit?
haha yeah I have it on my Z and it sounds like a cement mixer. Good thing I have a daily car which is my Fit?
~Robert
The stock clutch and flywheel work fine as long as you don't abuse it by doing stupid stuff like using heavy wheels and overly wide sticky tires and being at high RPM and full boost before the clutch is fully engaged.... A light flywheel and better clutch is wonderful and improves deceleration when down shifting as well as acceleration so takes accurate RPM matching when shifting.
It is crazy, I don't feel as if I am driving as fast with boost..... It is like going out to a pistol range with a .22 and a .44 magnum at a later date and realizing that the difference in power requires you to exercise more control than you did previously.
I am riding on 9.5 lb wheels and stock size rubber to not overload the drive train, suspension and brakes... I prefer the smell of burning rubber to that of the material used for brakes and clutches.... If someone ask's you about your 0 to 60 times are and you can tell them the answer you are going to need to replace your clutch sooner than someone with twice the horsepower that can't answer the question but knows his 60 to 120 times..... There is no reason for the stock clutch to need replacing due to boost.
i made 170 hp and 186 tq.. greddy kit on 8 psi. awhile ago i launched the car all high and when i went to second it started slipping alot.. but now idk i havnt felt that for a long time. i have about 10,000 miles on my turbo 55,000 on the car
I will be upgradeing my clutch and flywheel when i have my tranny out for the LSD install. Im thinking about running exedy stage 2 clutch and a fidanza flywheel, has anyone heard anything about bully dog clutch? my buddy is sponserd by them and i might be able to get for real cheep.
not to hijack the thread but who is running a LSD and what type are you running? im gonna make a post about it..
cheers
Cam
cheers
Cam
looks good i wish we could get it for less than $675
