HKS Turbo Timer
HKS Turbo Timer
Just finished installing a HKS turbo timer type 1. Just wanted to note that the wire for the RPM function on the timer needs to be hooked up to a different wire than on the vehicle specific diagram that comes in the box. I have a 07 and on the diagram it shows a wire marked "I" for the RPM. Now on the Harness that I have which is HKS Piggyback F-con I has this wire however when you look at the corresponding original plug on the ecu harness there is no wire. However right next to it is a green wire which will provide the signal for RPM. For the speed wire I tapped right into the piggyback harness wire and it worked just fine. Just an FYI for anyone who decides to put this item on. On a side note now I have the timer and I can measure my 0-60 I was highly dissapointed with the 8.77 sec time. I guess its time for me to learn how to drive and time for more
BOOOOOOOOOOOST!!!!!!!!!
As far as a review of the product it is everything you could expect from HKS. It is a bit confusing navigating all the different modes at first but for me all new tech is difficult to use in the begininng. I hope this helps someone save a few minutes screwing around with wires.
Vash
Dec 15, 2011 03:50 AM
BenjaminFit
Dec 1, 2011 05:02 PM
1990hondahf
Oct 17, 2010 09:04 PM
1990hondahf
Jul 7, 2009 12:25 PM
