Ramey Built - Custom GD3 Turbo Kit Build Thread
Old Dec 3, 2012 | 11:40 AM
  #41
RBMvrk's Avatar
Yea, a 48mm turbo makes a lot more sense for stock internals and it still leaves plenty of room to grow should you choose to build a rotating assembly for it lol
What turbine side? Is that still T3? .63 A/R? That housing and 54mm turbine would make for great top-end and relatively low drive pressure, suffer a bit on lag in lower gears though. Power and pull will more than make up for it.
Should make great power on pump gas (~36-38lbs/min) and won't max out the 650 injectors at the Fit's base pressure. Will you be running an adjustable pressure regulator and converting to a return-style fuel system?
Using factory fuel system just with an upgraded pump and injectors
Originally Posted by Sapper
Have they given you a cost figure or range on this build?
I might buy a 2nd fit just to do something like this!
Email me if you are interested on a price on the kit shawn@rameybuilt.com
Any change these guys would build extra turbo manifolds?
Yes we made a jig for the manifold for further sale of kits or turbo maifolds
Old Dec 3, 2012 | 01:00 PM
  #42
swade's Avatar
Just for future reference. Can the manifold be made with say an evo flange? I'd love to have an evo9 turbo set up on the fit.
Old Dec 3, 2012 | 01:40 PM
  #43
DiamondStarMonsters's Avatar
Cylinders need to be paired properly with the divided scroll housing, but beyond that there shouldn't be much difficulty even with equal length runners. Turbine scroll would tuck nicely up against the block and above the CV-shaft loop
And the IX turbo (reverse rotation) has the down-firing cover and the WG actuator would point straight down as well. Mount the compressor towards the passenger side and the downpipe would aim nicely towards where the stock exhaust runs.
And with 40lbs/min on tap, you would likely never need to upgrade.
Old Dec 3, 2012 | 02:34 PM
  #44
dewthedew's Avatar
emailed you
Old Dec 8, 2012 | 11:49 AM
  #45
hehn's Avatar
dropped the car off yesterday. hopefully it'll be done in a week or so
Old Dec 19, 2012 | 02:40 PM
  #46
RBMvrk's Avatar
Here we go with some updates guys.
Shall be on the dyno before the weeks out.
Old Dec 19, 2012 | 03:02 PM
  #47
dewthedew's Avatar
looking good! Cant wait to see the final build
Old Dec 19, 2012 | 03:18 PM
  #48
TPColgett's Avatar
Looking forward to seeing the results! Especially tuned via FlashPro...
Old Dec 20, 2012 | 02:59 PM
  #49
RBMvrk's Avatar
Update
The End.
Old Dec 20, 2012 | 05:01 PM
  #50
Wafulz's Avatar
any video ??
Old Dec 21, 2012 | 12:00 AM
  #51
silver gd's Avatar
Nice numbers!
Old Dec 21, 2012 | 11:05 AM
  #52
studebaker's Avatar
how much boost was that tuned for? what size injectors?
does the fuel pump drop in like an old civic?
Old Dec 21, 2012 | 04:52 PM
  #53
RBMvrk's Avatar
Originally Posted by Wafulz
any video ??
Yeah I have to upload it.
7.5 psi 650cc injectors, fuel pump was not a drop in we had to modify the cage
Old Dec 21, 2012 | 09:05 PM
  #54
studebaker's Avatar
modify cage? so u had to drop the tank to put it in? or lid is under rear seats. thanx
Old Dec 21, 2012 | 10:27 PM
  #55
preludetofit's Avatar
major props on the build and numbers...just do one for the GE8 now
Old Dec 22, 2012 | 12:18 AM
  #56
dewthedew's Avatar
where are the engine bay pics? lol
Can you make a manifold for a different turbo?
Old Dec 22, 2012 | 04:14 PM
  #57
hehn's Avatar
the car is more fun to drive now, which is what i wanted. next upgrade will be a clutch, and an lsd
Old Dec 22, 2012 | 04:19 PM
  #58
swade's Avatar
What was your base fuel pressure and what duty cycle on the 650s? Does the fit have a stock return system?
Old Dec 24, 2012 | 10:59 AM
  #59
RBMvrk's Avatar
we dropped the tank but it is not needed to do it. its actually under the center console
We will get more pics shortly. The manifold will work with many different turbos just need to know what you plan on running
Not sure on the fuel pressure, whatever factory is. It has an internal regulator in the cage. Duty cycle was 43 percent if i remember correctly. All stock fuel system aside from injectors and pump.
Old Jan 26, 2013 | 08:31 PM
  #60
bana1988's Avatar
I really like this build.. Im in the process of starting my build but i want to know where to start.. do i buy management first or what?
