Unorthodox crank pulley is lighter now?
Old Dec 16, 2014 | 01:24 PM
devmail's Avatar
Originally Posted by KV43
Those pulleys are super lightweight! How much did the kit cost and what was the part # for the kit??
Check www.SparktecMotorsports.com That's where I ordered mine!
Old Dec 16, 2014 | 01:41 PM
KV43's Avatar
Hopes and dreams just got crushed a little, just checked their website and it shows no UR pulley kit for the fit
Old Dec 16, 2014 | 02:02 PM
devmail's Avatar
Call UR directly. I'm pretty sure it's still available but they also don't list it on their own site.
Old Dec 16, 2014 | 02:18 PM
KV43's Avatar
Can't find a phone # on there website so I just sent them an email.
Update: got a response from UR they said this is the link for the kit Pulley Set & Belt however 349+shipping is way more than I was hoping to spend :/
Old Dec 20, 2014 | 08:28 PM
KV43's Avatar
Found it! And cheaper too! Just bought it!
http://www.nolimitmotorsport.com/mm5/merchant.mvc?&Screen=PROD&Store_Code=NLM&Product_C ode=ur-040602512
Price is 273.00. W/ coupon it comes to 259.35 and free shipping
Use coupon code "FB5" to save 5%
Old Dec 21, 2014 | 01:22 AM
13fit's Avatar
No Limit Motorsport: Unorthodox Racing Pulley Set: Stock diameter stock belt layout
That part number says it also works 2with older B series motors and some K series motors.
I would not trust it and you should halt order and speak to a UR rep. That is my recommendation
Old Dec 21, 2014 | 01:45 AM
KV43's Avatar
Here is the UR fitment guide on their pulley kits
http://www.nolimitmotorsport.com/unorthodox/ultrassapps.html
Old Dec 21, 2014 | 02:07 AM
13fit's Avatar
wow, found my mistake after reading that 3 times
one digit of difference, a 1 instead of a 2 in the middle lol
my bad. I hope I didnt cause concern over my lack of reading harder.
Carry on lol
Old Dec 21, 2014 | 02:12 AM
KV43's Avatar
Haha no worries. You did scare me for a bit though
Old Feb 17, 2015 | 11:19 AM
JoeF's Avatar
Hey guys, I have a stock fit except for cargo rack on top. lol I know that bolt on parts will not benefit unless I get the ecu flash. i do not want to spend a ton but I am interested in the pulleys does it make the fit a little more resposnsive?
Old Feb 17, 2015 | 02:01 PM
KV43's Avatar
JoeF- you will definitely see some improvement with bolt on parts however usually its not enough for the butt-dyno to register.
Before the pulleys were installed on my fit I was averaging about a 9.1-9.0 second 0-60 time depending on traction and horrible wheel hop. Seriously its horrible. This was using a scangauge 2 to record the time and the intake air temperature was averaging 58-60°
After I installed the UR pulley kit in the beginning of January I was consistently running a 8.6 0-60 time with intake air temps averaging 66-68°.
The car did feel a bit faster to me but I wasn't sure how fast until I did a few 0-60 runs. Did it make it more responsive? Maybe, for responsiveness you need a blitz throttle controller.
Old Feb 17, 2015 | 06:36 PM
  #32
13fit's Avatar
In my opinion, throttle controller is not worth it, and my GE hit 16.2 in teh quarter mile with just lighter rims, no cats, and a custom intake, while running 93 octane and colder spark plugs, and on a ffresh valve lash adjustment
Old Feb 17, 2015 | 06:45 PM
  #33
Myxalplyx's Avatar
If I could, I'd install lightweight pulleys on every car I own. I used to be about underdriven pulleys but if your car uses extra electricity or is older and it's electrical system is weaker than new, an underdrive pulley may not charge enough.
At any rate, I love these things. Throttle response has always been better. 1/4 mile times has always improved, even if slightly. It's hard to feel since the power delivery is throughout the whole powerband. They just work!
Any rotating mass that I can make lighter, smaller diameter or both I go nuts for.
As for throttle controller, I have a Sprintbooster on my RAV4 and it makes the car so much more fun to drive. I'd get one for any car I own if they have one available.
Old Feb 17, 2015 | 06:59 PM
  #34
KV43's Avatar
I can agree that to some people spending more than 300$ on a Throttle controller may be a bit much but the responsiveness is undeniable and I was able to pick up my blitz throttle controller for only 100$ from a fellow fitfreak.
The UR pulley kit is a great upgrade that made measurable improvements and I would definitely purchase it again!
Old Feb 17, 2015 | 07:05 PM
  #35
13fit's Avatar
the reaction time between full throttle stock and full throttle with controller is exactly the same. Part throttle is the only means of improvement. To ME, still not worth even $20.
Hell yeah on lightweight. But dont forget ceramic bearings severely outdo lightweight. Ceramic bearings inside alternator, and belt tensioners (in past) netted around 4-5 horsepower in upper rpms. a newer mustang saw 10 or 15 rwhp from just ceramic rear wheel bearings
Old Feb 18, 2015 | 05:28 AM
  #36
Myxalplyx's Avatar
I've read briefly about ceramic bearings some time ago. The cost was way up there though. Are you going to do this and report your findings? I've never read of anyone doing this in the import community. Only talk about doing it. Lots and lots of talk about doing it.
Here's a place to start --> Ceramic Wheel Bearings Honda
Sorry to go off topic slightly. Back to the regularly scheduled show.....
Giovanny Alan Alvarado
Apr 27, 2025 01:09 AM
jilm
Apr 13, 2016 06:22 PM
aliencowboy
Aug 18, 2012 08:03 PM
LastDance
Nov 13, 2010 09:14 AM
Fit of RAGE
Sep 1, 2008 12:35 PM
