HONDA FIT 2008 1.5CC 110 hp increase power N/A
Old Aug 6, 2015 | 02:53 AM
kylerwho's Avatar
spoon fed
That throttle body wont work with our fit due to it being a cable connection.
Old Aug 6, 2015 | 10:13 AM
chetan's Avatar
Weapon-R
Yes want to go for it but some forms say even for R18 Civic motor low end power is lost with Weapon-R Intake or it works more good with Turbo setup. I do not have a plan to add Turbo.
Mine is Honda City 2007 model which has engine L15A1, it is 100 PS engine less than Fit outside of India, changing intake to Fit intake should should make it 110 hp with Weapon-R more HP.
ECU remapping will be more helpful but I was told by local tuner that ECU is not remap-able, so wondering to get Fit ECU & see if I can re map it using Hondata if I can get Hondata locally.
Can someone post ecu details for FIT soon, my tuner can get it from Hong kong trip this week.
Please feel free to comment.
Old Aug 6, 2015 | 11:11 AM
chetan's Avatar
Engine bay photo for my Honda City ZX Vtec Unofficial Honda FIT Forums - chetan's Album: ZX - Picture
Old Aug 6, 2015 | 06:21 PM
kylerwho's Avatar
spoon fed
Most people from Asia outside japan are running the dastek q+ chip with good success. You would need to check hondata's website to see if your ecu is comparable. Your ecu is located under the center console in front of the shifter. See if the numbers on the ecu are supported by Hondata, if not try contacting ktuner to see if he will be supporting your ecu.
Old Aug 7, 2015 | 10:24 AM
chetan's Avatar
Thanks, ecu for my car is 37820-ref-e02 which is not compatible for remapping .
Now I have only option to look up dastek q+ chip which works for most other, apart does it make sense to get used 37820-RME-A14 & remap it
Old Aug 7, 2015 | 03:22 PM
kylerwho's Avatar
spoon fed
That ecu wouldn't work on your car due to a few different electronics. Drive by wire being the biggest difference.
PowerHungryFIT
49
Aug 27, 2012 09:55 PM
Miki-Mugen
May 5, 2012 10:49 PM
atom
May 1, 2009 01:13 AM
Chitownfit
47
Oct 6, 2008 12:35 PM
azkikersfit
Jul 24, 2007 07:00 PM
