2018 Fit bulb and installation
Old 12-04-2017, 12:49 PM
Daniel.Lam's Avatar
Just recently bought a 2018 Fit and wanted to know if anyone knows the bulb sizes for headlights and fog lights. LED is preferred and installation instructions would be appreciated. Thanks
Old 12-04-2017, 08:21 PM
sneefy's Avatar
Not to be unwelcoming as this is your first post, but this is the laziest thread I've seen in months.
Search. You'll find your answers in less than a minute. http://bfy.tw/FOKJ
I apologize if I offend. I just can't stand it when people expect to be spoon fed.
Old 12-04-2017, 10:11 PM
Daniel.Lam's Avatar
No offense taken at all. I understand that I could find an answer online. I wanted to be sure about fitment and have directions before I started pulling my car apart. I am pretty new to this kind of stuff. Thanks for the advice though. I just wanted some help from people who own the newest model just in case anything has changed.
Old 12-09-2017, 09:42 PM
Spyke's Avatar
I mean, if you've never owned a car or a flashlight in your whole life I would find this justified.
Old 12-21-2017, 10:19 AM
Aznsupastar's Avatar
i'm in the same boat as u, looking at the manual, it looks like 2018 still has the same H4 in the low/high beam, and H8 in fogs.
i also looking for HID/LED replacement, and it looks like u will run into DRL issues as 2015-2017 models (DRL in halogen is a low voltage, so it won't be enough to power HID/LED and u will have no DRL which can be an issue). i'm no expert at this but the forum is pretty dead compare so i don't think u will get much responses. good luck fellow 2018 owner...
Old 12-21-2017, 10:37 AM
2Rismo2's Avatar
DRL is in highbeam so if you keep that halogen, you don't have to worry about it. Don't really think it's worth the expense to hid/led highbeam since you're not using it 99.99% of the time anyways.
Old 12-21-2017, 01:16 PM
Daniel.Lam's Avatar
Thank you, friend!
I found some​​​ Cougar LED on Amazon for the hi/lo.
H4 LED work fine as drl. Good luck!
Old 12-22-2017, 09:06 AM
r u saying any H4 LED will not have the flicker issue when in DRL mode?
any H4 LED kit will work in the high/low beam since they are designed that way, but i'm uncertain about DRL mode. let me know how kit goes!
Aussie
03-21-2018 04:18 PM
Aznsupastar
01-27-2018 06:35 PM
zongld
12-28-2017 08:42 PM
person118
07-29-2017 07:42 PM
Quick Reply: 2018 Fit bulb and installation
