New to the fit world and fitfreak
Old Jan 13, 2016 | 05:30 PM
noelrobles22@gmail.com's Avatar
What's up everyone I'm new to the sit and to the FIT world. Just picked this fit up but already having issues :/ hope it gets better
Attached Thumbnails New to the fit world and fitfreak-80-20160112_173837_f120612ce03f825dbb3bba32f357746f67e82b68.jpg   New to the fit world and fitfreak-80-20160112_173900_e84bffbe9b52c346a38a5740543e8b1fe01cad09.jpg
Old Jan 13, 2016 | 08:41 PM
Hootie's Avatar
Hello and welcome!
What kind of issues are you having with your Fit?
Old Jan 13, 2016 | 08:44 PM
Originally Posted by Hootie
Hello and welcome!
Well after I bought it and registered it and drove it for 1 full day. Day 2 cel comes on. Misfire cylinder 3. That's the issue I'm having now. I been doing some research on it most people say its the coil packs
Old Jan 13, 2016 | 10:25 PM
Hootie's Avatar
Coil packs are common issues... so bad that Honda even offered an updated replacement.
What I would do just to ensure coil pack, swap cylinder 3's with another and see if the code follows. If the code does follow, defective coil pack. If it doesn't, either looking at spark plugs, valve adjustment or possibly a fuel related concern.
OEM (Hitatchi I believe) coil packs are highly recommended for replacement and as for plugs either NGK or Denso (I forget the heat range and model exactly) are usually factory equipped plugs.
Additional note: If you want a fairly inexpensive upgrade... Swap to a spark plug that is one heat range colder than stock. Oscar Jackson of Kraftwerks USA (he's now back with Jackson Racing) proved that doing so yielded a slight horsepower gain.
Old Jan 14, 2016 | 06:08 AM
Thanks for the info. Can defective coil pack give u bad gas mileage? To me it seems I'm wasting more gas on this fit in 2 days then I did in 4 days with my 03 accord.
I'm going to replace the coil packs regardless just so I know it's done since the previous owner obviously only changed 1 out of 4.. if issue stays I will do the plugs, then valve adjustment. Once again thanks for all the info
Old Jan 14, 2016 | 07:22 AM
fittmann's Avatar
Your Fit is immaculate! I miss my GD, but I've got my GE to ease the loss!
Old Jan 14, 2016 | 08:16 AM
Yeah interior is kind of dirty because previous owner had kids but I'm looking to see what I can do to clean the whole inside.. this weekend will consist of putting the coil packs in and cleaning the car praying it all works out. He was the original owner have all paperwork from dealer in 08.
Old Jan 14, 2016 | 10:01 AM
Action Jackson's Avatar
Welcome. Hope those issues gets resolved.
Old Jan 21, 2016 | 04:59 AM
gallent92's Avatar
Good luck with fixes buddy, sure when you addressed them, she will impress you.
frethack
Aug 13, 2017 04:28 PM
Mtwalenciak
Dec 23, 2014 10:04 AM
codenamezero
Mar 2, 2014 04:00 PM
earthcurve
Aug 20, 2013 05:59 AM
Harriswt
Mar 19, 2013 01:56 PM
