Map Light Install?
Old Dec 25, 2006 | 07:02 PM
Raaaaaaaaaay.'s Avatar
Posts in the NUUDE
Map Light Install?
I did a search and all and I didnt see anything about the JDM Map Light install. Is there a DIY because I cant find it. I know that "wyy183" is the one giving the info but I searched his name and couldnt find a thread he made.
I know its not that hard, what I really wanted to know is when you tap into the dome lights will the lights come on when the doors open; then slowly dim after theyre closed? And what wire is that? Thats what I really want. And then of course the regular 12v source so I can turn them on when needed.
My map lights didnt come with bulbs, wiring, directions, screws, connectors, or anything at that. Was it suppose to?
Also one of the 2 clear covers is the same. So I need to send it back because it doesnt clip in.
Old Dec 26, 2006 | 02:12 PM
Posts in the NUUDE
Where at? The only thread that says "Map Lights" is mine and the thread about the Acura CL Homelink.
Nothing about JDM MAP LIGHT. And doing a search brings up my thread.
Be a sport and link me.
Old Dec 27, 2006 | 06:03 PM
Posts in the NUUDE
Did it. I couldnt figure out a way to run the lights connected to the dome lights (on and off with the door) AND have a 12volt source to turn them on when needed.
I dont think its possible unless you mess with the switch.
*The map lights are the same thing as 2004 Civics.*
y950129
Nov 26, 2011 05:14 PM
White_GE8
Jul 14, 2011 08:03 PM
Benggolf
17
Aug 5, 2009 01:23 AM
aznbigman
Jul 13, 2009 05:35 AM
pwnstar
Nov 11, 2008 01:18 PM
