First Fit in USA w HID retrofit!
Old May 19, 2007 | 05:29 PM
rcantu's Avatar
Originally Posted by sLiVeRwOrM
I would like to see some of the 5 Series angel eyes..
he tried to use some aftermarket angel eyes and it didn't look right. I'm not sure about oem though.
Old May 19, 2007 | 05:32 PM
rcantu's Avatar
not sure about that. I think it depends if the directional output of the bulb is similar.
as far as high/low you would need something like a X5 projector which I have in the truck. it'll move the lense to get high low.
Originally Posted by TomiGunz
With the retrofits, do we still use our current aftermarket HIDs, or do we have to go with the D2 bulbs?
Right now I have high/low beams. I want to keep my high/low beams. So with the retrofit, I guess it's a possibility we can just use the projector glass itself and still use our reflector for highbeams?
Old May 19, 2007 | 06:09 PM
George02's Avatar
how hot did you heat the headlights to take them apart? and for how long?
Old May 20, 2007 | 01:08 AM
TomiGunz's Avatar
Frequent FitFreak Poster
so it sounds like the high beams will have to be tapped onto the shutter on the retro fit. If that's the case, we'll have to use single beam HID bulbs.
Old May 20, 2007 | 02:00 AM
koolkevin1107's Avatar
damn robert that looks sick!! i can't wait to see the hid retrofit tomm. Looks real clean tho.
Old May 20, 2007 | 09:34 PM
integradriv3r's Avatar
omg robert i'm coming over and taking a look at this. and maybe ur buddy can hook me up too
Old May 20, 2007 | 09:45 PM
FITTUCINI's Avatar
clean most def feelin that move. thumbs up
Old May 21, 2007 | 01:27 AM
rcantu's Avatar
come by anytime.
i roadtested them last night and OMG, so nice. i'm going to readjust them a little higher but it just brightens up the road.
Old May 21, 2007 | 01:59 AM
aziatiklover's Avatar
Master FitFreaker
looking good man I'm loving it
Old May 26, 2007 | 01:16 PM
Tomh's Avatar
Senior Member
no, your not the first, actually i was, lol, if you search for my thread you'll see, though i never got farther then you have with finishing it completely, i did atleast get the projectors mounted into the housing, aligned on the wall for cutoff, just never put the clear lens back on, so it sat in my clsoet for many months, then to top that off i traded my Fit off about 2 weeks ago for a truck that i need more then a small car.
Old May 26, 2007 | 01:18 PM
Tomh's Avatar
Senior Member
Old May 26, 2007 | 02:37 PM
  #32
rcantu's Avatar
thanks for pointing it out. i can't change my title but i will say "First in USA to have COMPLETELY INSTALLED retrofit HID" lol
Old May 26, 2007 | 03:50 PM
  #33
Tomh's Avatar
Senior Member
Either way congrats, does look real good.
Old May 31, 2007 | 11:15 AM
  #34
smeister's Avatar
Well, I may be #3 with the retrofit. The parts are on its way. I couldnt resist after seeing Rcantu's retrofit.
Old May 31, 2007 | 12:23 PM
  #35
gthumb23's Avatar
Damn.... that looks good, I just put that on my "to do" list. It will have to wait though, I am on the motto " If it doesn't make you go fast, it can wait till last."
Old May 31, 2007 | 01:27 PM
  #36
smeister's Avatar
I forgot to ask...do you have any pictures of the actual retrofit progress?
Old May 31, 2007 | 03:07 PM
  #37
Fit4DHM's Avatar
the HIDs... they dont auto level do they? angel eyes on the fit... i think the headlight ring is too big on the fit and putting halos around them would be kinda weird, just my 2 cents.
Old May 31, 2007 | 03:13 PM
  #38
JamesBizzle's Avatar
I may the 4th, or maybe the 3rd. I have everything but my shrouds that I'm in the process of getting.
Old May 31, 2007 | 08:12 PM
  #39
smeister's Avatar
I'll let you go first man hahaha write a HOWTO while you are at it and then I'll be the 4th.
Dang man, something came up and my HID retrofit is going to have to wait for a while. Good luck JamesBizzle!
Old Jun 11, 2007 | 07:30 AM
  #40
ccweems's Avatar
Reeeeeeaaaallllyy looking forward to the "how to"
Did you take any pictures during the conversion? You said it took 8 hours. This is for both, start to finish? Just wondering because I was thinking that I would have to buy another set of stock lights to convert because it would take so long. It looks like you can remove the light assembly without removing the bumper. True? I know for wiring purposes bumper removal is recommended. I just have to be able to remove an convert one assembly in a day to keep the wife at bay. PW'd yes, but it's great P.
HID projectors and car look great.
A note to the HID kit folk. They only look great when you don't have an alternative which is pretty much the way it is now. Once vendors step in or the knowledge of how to do it becomes trivialized proper projector HID will rule. HID kits will fade in popularity except for those who don't drive at night and think a fart can and K&N filter will add 20 hp and 10 mpg to their auto tranny cars.
One thing:
real HID = HID projectors
real HID light assemblies = HID projectors with motorized aiming
I would expect the Fit to be sensitive to weight. Without aiming (even manual adj) you have to either compromise the performance at light loads to avoid glare with porkers in the back or you have good performance with you and a passenger and blind everybody with a load. If we had load leveling we could compensate also.
