So I started my projector retrofit..
you wont be using H4 anymore. the fxr projectors use d2s bulbs. morimotos currently use h1, but they're coming out with a d2s version soon. the mini projectors dont require drilling, it has a threaded base so you mount it with locking nuts/washers
Nope. I actually have it like that on purpose. I want the passenger side higher than the drivers side to illuminate more of the roadway on the right side for street signs and joggers. Some folks don't like the way it looks but I'm going for function over aesthetics.
What did you use to hold on your shrouds? Hopefully they're more secure than mine... Had one fall off on the way to a meet last weekend. Easy fix, but nonethe less a pain.
QFT. I prefer the way a single step up looks, but the output a little higher on the side of the road is critical.
JB Weld doesnt bond to smooth surfaces very well and the rigidity lends it to cracking from vibrations. RTV on the other hand, bonds very well to any surface and remains rubbery giving it great resistance to vibrations. It has to be the high temp RTV though otherwise it will fume during the first light/heat cycles and cause a greasy residue on the inside of the headlight lens.
I apologize if the answer to this is a no-brainer once you've actually got the headlight & projectors in front of you . . .
#33
I'll bet when that RTV out-gassed onto the headlight lense some bad words were said! Has there been any info about when the mini Morimotos will become available? They seem like a good, lower cost alternative to the FXR. Any real advantage to one bulb type over another? D2S is obviously the choice for OEM and should be easier to replace in the unlikely event of a failure, but any other reasons? Thanks to all who have helped!
#34
#35
My principle concern is output, if the D2S is best for that then thats the one I want. Can they be had in different temps like all the PNP kit bulbs can? I ask because i don't want to go above 5000K. It seems like all the PNP kits (garbage that they are) come in ridiculous temps, like 10,000+ And imagine most projectors are set up for the D2S, but I was just curious.
#39
Wait, I thought the morimoto mini's were h1 bulbs - are they available with d2s bulbs somewhere? Or are they in development or something?
Despite what they potentially cost, I'm tempted to wait a few months for the new S2K-R projectors . . . although I haven't seen anything objectionable about the H1 version of the mini's, they seem like a great way to go, especially considering their price & how easy they are to install.
#40
D2S mini are supposed to be close to commercial availabilty, I will wait for them because I need to come up with the money for kit/labor anyway. The minis look like the way to go for me, price/performance, and reputation wise. Yay for retrofits!
