Philips X-treme Power... who should get it and why get it??? 65K WARNING
Old Nov 19, 2010 | 07:32 AM
clicq's Avatar
Mileage is probably a better measure of bulb life than time, since you're not using the lights when you're not driving .
I've had my XP bulbs for a year now, about 9,000 miles.
Old Nov 21, 2010 | 07:44 PM
hobbes87's Avatar
i put on 20,000 miles in 8 months. would the lamp burn out at that point?
Old Nov 26, 2010 | 10:39 PM
clicq's Avatar
So I guess I jinxed myself with the last post. This evening the low beam burned out, after about a year and 9,000 miles. The high beam filament is still OK (despite being used for the DRL). For now I'll probably put the stock bulb back in while I figure out whether to get the XP or the successor... I'm not entirely impressed with the bulb life .
Old Nov 27, 2010 | 03:29 PM
jcschlic's Avatar
Hmm, sorry to hear about that.
The same day I installed mine I disengaged the DRLs by pulling out the fuse...will be interesting to see how long mine last while not acting as DRLs.
Old Nov 29, 2010 | 11:51 AM
ThEvil0nE's Avatar
Knock on wood, 14K miles on my crosstour and the bulb are still lit with no issues, so I'm happy. Like I said, I take much care on handling the bulbs when installing
Old Nov 29, 2010 | 11:53 AM
ThEvil0nE's Avatar
I'd still count the days, month or year for the bulbs, so i'm still far from 12 months
Old Nov 29, 2010 | 01:05 PM
johnkimble's Avatar
So H4 60/55W for the main headlights.
What about the Nokya yellow bulbs size/wattage for the fogs? Will the Nokya H11 55W work? Like these: Nokya Arctic Yellow H11 55W Light Bulbs | eAutoWorks.com
Old Nov 29, 2010 | 01:31 PM
jcschlic's Avatar
Yes, all that is what I'm using. As I recall, you may be able to find those Nokya bulbs for a better price somewhere else.
Old Nov 29, 2010 | 01:37 PM
johnkimble's Avatar
Awesome, repped.
Now I just need to find a good place to get everything. If any of you have recommendations feel free to post up.
Old Nov 29, 2010 | 01:46 PM
jcschlic's Avatar
Cheaper here, but currently sold out. Scour google for more hits:
Nokya Hyper Yellow H11 [NOK-7618] - $14.97 : Car Lighting Headlight Bulbs Xenon Halogen Upgrades, AutomotiveLightingUSA.com
Here's where I got my Philips Xtremes, came with free sidemarker clear bulbs, which I am using too:
Philips X-Treme Power H4 from Power Bulbs | Free Worldwide Delivery
Old Dec 2, 2010 | 12:40 PM
cfran55's Avatar
im going to check meijers when i get around town, anyone purchase them from there and for how much? i think it said car quest might have them aswell
Old Dec 2, 2010 | 04:16 PM
  #32
johnkimble's Avatar
post up if you find them at car quest cfran. i don't feel like ordering from europe haha
Old Dec 2, 2010 | 04:51 PM
  #33
ThEvil0nE's Avatar
quick search on meijer website does not return any philips automotive bulbs
Old Dec 2, 2010 | 07:05 PM
  #34
Klasse Act's Avatar
He meant what he wrote... Meijer, it's a store chain in IL.
I havent gone into that store yet but will now to check them out...
Meijer is also in Michigan, its a Michigan based store.
I must say, those lights look like HIDs, never seen anything like them, WOW!
Old Dec 2, 2010 | 08:38 PM
  #35
Dee K's Avatar
They definitely have them, at least the last time i visited the Bolingbrook one they did. IIRC they ran out of the H4s for the xtreme powers but had plenty of the ge nighthawks and other high end bulbs.
Old Dec 2, 2010 | 08:46 PM
  #36
hayden's Avatar
Still looks a little purplish, but not as bad as others. I have Narva Range Power +50s, which should be as bright or brighter because they really don't have any blue stuff on them. See that blue band on the ones you posted?
Old Dec 2, 2010 | 08:55 PM
  #37
cfran55's Avatar
49.99 only had 9007 and h7 had a spot for 9006 but they were out. also had others! i dont know if i want to spend 49.99 on them thoe
kmart had ultra visions but no xtreme
ill have to check car quest tomorrow i was hoping they would be around 30
Old Dec 2, 2010 | 10:41 PM
  #38
ThEvil0nE's Avatar
The blue band you are referring to is not even blue in color, it is more of ionized (I did explain what was it for on the post).
The Narva +50 can never be more bright as the Xtreme... Narva Rangepower +50 has less lumens than Philips Xtreme.
The purple-ish glow you see is only in pictures... notice the lights on the lamp posts on the car dealership? that's what happens if you capture a light source that gives off intense white (daylight) on a simple camera... outer shade rings of blue to purple
Old Dec 2, 2010 | 10:48 PM
  #39
hayden's Avatar
Cool! They look bright!
Old Dec 2, 2010 | 11:04 PM
  #40
clicq's Avatar
It's hard to tell the color temperature accurately from pictures, since it really depends on how the camera decided on the white balance.
Here's an example from my camera, which I took back before my bulb burned out, and the color looks totally different from ThEvil0ne's. I suppose the bulb was nearing the end of its life, but you can tell it's brighter and has a larger hot spot than the OEM bulb (which is installed on the passenger side for reference). The Philips XP bulb was a little whiter than stock, but it's not so huge that people would really notice. I also under exposed the picture to get a better shot of the light output.
jukeboxx13
Apr 30, 2018 04:28 PM
Mikeyk12
Aug 31, 2015 12:48 PM
jadr09fit
Jul 19, 2009 08:19 PM
kamakurakid
Nov 22, 2008 01:31 PM
FikseRxSeven
Aug 15, 2006 12:16 PM
