Morimoto Mini D2s Bi-Xennon retro GD3
Old Apr 14, 2011 | 12:42 PM
JJIN's Avatar
Wooaah 350 degrees is too hot. You only need to set the oven at 150 and headlights in for 3-4 min. You will melt your amber reflectors/marker if you go too hot or too long. I melted my reflector on my drivers side at 150 degrees and 10 min in the oven.
Old Apr 21, 2011 | 11:30 PM
da9r00d's Avatar
Any help wiring the high beams?
Old Apr 25, 2011 | 05:12 PM
accordguyintake's Avatar
i just stuck the wires into my stock headlight harness......... o_o... LOL
The light output is really nice, and the high beam works well too. The only complaint I have is that I wish peripheral lighting was a little better, but it's not a big deal. I'll post some pics soon
Old Apr 25, 2011 | 06:40 PM
JJIN's Avatar
Sweeeet. Post pics soon!
Old May 1, 2011 | 04:31 PM
pics are in, no nightime cutoff ones though, dont wanna see them anyway.. it's off. haha YES my car looks like a frog/crazy person
Old May 1, 2011 | 09:43 PM
sometimesjoe's Avatar
Looks pretty good there. Always liked those shrouds and had them on my 8th gen Civic, too. Next is to show the night shots!
Old May 1, 2011 | 10:23 PM
JJIN's Avatar
looks great jason. all you need now are some cutoff night shots after you finish the rotation and alignment.
Old May 2, 2011 | 12:32 AM
i'm too lazy to readjust them, the right side just tapers up a little on the far right and down on the left, it's not a big deal. Really sharp cutoff though. If you want I'll just step outside and snap two pics really quick. haha
Old May 2, 2011 | 12:48 AM
sorry they're not DSLR Perfect, my double-A powered point and shoot will have to suffice There's slight slight glare as you can see above the beams but I just drove in front of my car in another lowered fit tonight and they're nice, no annoying hid glare at all.
the blue cut-off isnt THAT noticeable in real life, but it is a little noticeable, it's a nice touch
Old May 2, 2011 | 12:59 AM
That isn't too bad at all. Depending if you're on a level surface, I'd line them up a bit.
Overall, good job!
Old May 25, 2011 | 03:07 AM
Draako's Avatar
if i just buy the projectors and the shroud, can i use my pnp kit?
Old May 25, 2011 | 03:21 AM
  #32
FollowingNFront's Avatar
You'd need bulbs too. So really the only thing you'd be reusing from your pnp kit are the ballasts.
Old May 25, 2011 | 01:14 PM
  #33
danger69's Avatar
Welcome to the HID retrofit club. Another GD3 member lighting up the night roads.
Old Sep 13, 2011 | 11:13 PM
  #34
Diasoul's Avatar
nice retrofit
awesome job on the retrofit, everything looks nice. I am also currently trying to retrofit my GE8.
I'm still pretty new to things, but i just want to do it right (for once). I have Bi-xenon Morimoto Mini H1 4.1s with a H1 HID kit (Notto SE). I have been searching the forums on ideas but I am confused, even with general instructions, as to what i really need to do. My friend and i took a look at my bulbs and i figured that we'd probably need a soldering iron? I just wanted to know what steps and tools you used to actually complete your retrofit looks so nice D:
As of now nothing is done to my car, all the items are still sitting at my desk since i have absolutely no confidence in myself
Old Sep 15, 2011 | 08:17 AM
  #35
BlueBoogers's Avatar
Send me an email at andrew@theretrofitsource.com and I'll forward you the Mini H1 how-to PDF.
We're going to put some LS460/STi-Rs in my Fit next weekend with the clear shrouds. It will look pretty crazy!
ivanushka_int
Aug 10, 2015 03:30 PM
matt0807
35
Nov 28, 2011 03:11 PM
fitted08
Jun 19, 2011 11:18 AM
SoFit
15
Jun 7, 2011 11:08 AM
mbemblue
Feb 20, 2010 02:30 PM
