OK ICE gurus, need help...
Old Sep 26, 2009 | 09:31 PM
  #41
grtpumpkin's Avatar
As I was rereading this whole thread i realized that i had never tried resetting the HU. Went out to the garage this morning and reset and Viola! I have video! And it still works as I type this at 9 PM Hot Dog! Thanks to all for the moral support and advice I really appreciate it.
Old Sep 26, 2009 | 11:43 PM
  #42
psmo290's Avatar
what do you mean by resetting the HU?
Old Sep 27, 2009 | 12:01 PM
  #43
grtpumpkin's Avatar
I hit the little tiny button that resets the whole shooting match, right next to the disc eject button on the 3100. I figure it must be the equivalent of restarting a windows based computer, since that is basically what the Pioneer HUs are as I understand it.
Old Sep 27, 2009 | 01:46 PM
  #44
MetalFit630's Avatar
Haha! Wow that is funny! I can't believe I didn't suggest that! When something isn't acting how it is supposed to, that's usually the first thing I do. Half the time it takes care of the problem. So are you using the bypass then?
Old Sep 30, 2009 | 04:20 PM
  #45
grtpumpkin's Avatar
You bet your sweet bippy! I have about six movies in the glove box at all times now LOL And the best part is that with the E-bay bypass relay, I don't need a switch, it just cycles the power on-off-on and that fools the safety. Now if i could just get the audio dialed in so that voices come across as clear as the background sounds and music... Time for an upgrade! LOL
Old Oct 4, 2009 | 01:53 PM
  #46
polokid69's Avatar
I'm going go thru your notes on this install when I install mine soon. I got the DD adapter, ipod adapter, antenna adapter, the dash kit, and the sirius add-on. Just waiting for these people at "Abe's of Maine" to ship the BT adapter unit I ordered 2 weeks ago. Figure I'll wait till I have everything as to not have disassemble the dash twice, lol. From what you are saying, it sounds good eh ?
Old Oct 5, 2009 | 12:22 AM
  #47
Good idea. But don't forget that you need to put your Sirius antenna on the roof of the Fit. Otherwise you'll get horrible reception.
Old Oct 5, 2009 | 07:18 AM
  #48
polokid69's Avatar
Already ran the antenna. I have a stand alone Sirius receiver connected thru the aux jack already.
Old Oct 5, 2009 | 10:49 AM
  #49
polokid69's Avatar
I'm contemplating doing this install today it's a bit intimidating. I removed the lower cover so I can access the bolt under radio but I was reading the center part around the radio has 14 clips ! From looking at the kit and all the stuff Crutchfield sent me, I shouldn't need to splice anything, right ? It appears the adapters for power and antenna make it connect using the factory Honda one, is this correct ?
Old Oct 5, 2009 | 11:38 AM
  #50
You'll have to give the Sirius adapter power and ground, which can be spliced from off of the main HU harness.
Old Oct 5, 2009 | 06:23 PM
  #51
polokid69's Avatar
I got my 3100 in today, man, a lot harder than I thought. Part of the difficulty was all those wires to connect to the harness adapter incluiding those extras not currently using. The only thing I'm missing is the video. I have the green wire run thru the console and thru that opening before the E-brake. I need to know what I connect it to and is there an easier way that removing the console ? I was kind of disappointed that in order to connect the ipod, you have to use the from aux connector. I figured it would connect in back like the factory one.
ekimox
Dec 17, 2013 07:53 PM
polokid69
15
Oct 27, 2009 01:33 PM
psmo290
Sep 25, 2009 12:02 PM
pwnstar
Jan 27, 2009 09:33 AM
gimme
Sep 13, 2008 05:43 AM
