DIY door panels
Old Aug 3, 2011 | 08:06 PM
Fit4Trav's Avatar
Do you have to take the inserts off? Or could you possibly "wrap" over the existing fabric?
Old Aug 4, 2011 | 01:15 AM
xalx02's Avatar
I think you have to or else the fabric won't stay on the panel for that long. i didnt take off the inserts for the rear and just wrapped the fabric on to and now the fabric is coming off and looking sloppy as hell.
Old Aug 4, 2011 | 01:16 AM
xalx02's Avatar
or the glue i used wasn't good enough...
Old Nov 23, 2011 | 05:07 PM
Previc93's Avatar
take the material inserts off otherwise it wont look as good. the plastic welds are esay to undo. there is a plastic welding tool that is around $150 or so but if u have like a sodering iron it would work too. the nice thing about the plastic welding kit is that it comes with all sorts of plastic rod like a tig welder so that if u need more material its there. every plastic piece on the inside of it has what it is made of stamped on it so u can use the right rod.
heres my door panels. i did some fiberglassing as well.
sorry for the dark pic.
Old Nov 23, 2011 | 06:21 PM
MOTOMATT's Avatar
Thumbs up
Nice work, Do you have a link for the plastic welding tool? What glue did you use?
Thanks for any info
Old Nov 23, 2011 | 06:37 PM
Previc93's Avatar
here is the plastic welder. its a little more in price than i thought if u search amazon or something maybe could get it cheaper.
Airless Plastic Welder Model 6
the glue i use is an industrial glue. i use it when im wrapping panels, doing headliners and things like that.
1 Gal. DAP Weldwood HHR Contact Cement
to use the glue u have to spray it on both the fabric and the panel it is going on. ( i get cheap harbor freight spray guns for the glue that way i dont ruin my expensive spray guns for paint.) let it sit for 5-15 min until the glue feels a little tacky. then put the fabric over the panel doing hard corners first. (helps if using a heat gun but not too much to burn the fabric) then once u press on the fabric the panel its stuck. once pressed dont peel unless u want spots to show up uner the fabric.
it will take some time to really learn how to do it right but once u get it it will look good and u can charge your friends to do theirs as well. maybe make some of ur money back for the plastic welder and materials u purchased.
***note clean the spray gun with laqure thinner after use otherwise the gun will be hard to get out the next day. might as well buy a new gun again****
Old Nov 23, 2011 | 08:50 PM
MOTOMATT's Avatar
Thank you
The Dapp weldwood HHR contact cement
THIS ITEM CANNOT BE SHIPPED TO THE FOLLOWING STATES:
Old Nov 23, 2011 | 09:08 PM
Previc93's Avatar
I don't get it from that place. I get it from a local upholstery supply place. I'm sure they have a ton of those in California. Just look it up online or the phone book. I just searched the name so I could get a link for u to see what it looks like. Make sure u don't keep it in hot temps. I left it in my car for like 3 hrs and the top popped off due to the heat and the glue got all over my seat. Good thing I was redoing it. Lol
Old Nov 24, 2011 | 02:25 PM
MOTOMATT's Avatar
Question
Thank you
I am having a tough time with my door panels. I am trying to do it with carbon fiber fabric and it keeps popping up in pocket. How much would you charge if I send you the section that gets covered?
Old Nov 24, 2011 | 03:22 PM
Previc93's Avatar
Are u sending the whole panel or just the insert.? Just wondering if I have to undo the plastic weld or not. Am I doing all 4 doors.? The rears don't have an insert that is removable. The material just tucks in the groove. Do u have the black carbon fiber material or should I get that too. I may have some extra laying around if u haven't purchased it yet.
Old Nov 24, 2011 | 03:29 PM
MOTOMATT's Avatar
Just the the inserts, to expensive to ship the whole panel(big box),all 4 I have the material.
Old Nov 24, 2011 | 03:56 PM
  #32
Previc93's Avatar
Pm sent. Also that doesn't include shipping.
Have u thought about doing ur headliner that same color? I think the black carbon fiber would look good up there.
Old Nov 24, 2011 | 08:34 PM
  #33
MOTOMATT's Avatar
Yes I have , but I am not to thrilled about doing the work
Old Nov 24, 2011 | 10:53 PM
  #34
Previc93's Avatar
Ya just let me know.
Old Jan 31, 2012 | 11:32 PM
  #35
WAKUFIT's Avatar
Help!
Anyone with a 07 fit done their rear panels fabric?
Cause i was taking my panels off to get ready to put on new fabric but the rear panels are one whole piece and i see no way to take just the fabric part off, can anyone help?!
Old Feb 1, 2012 | 12:16 AM
  #36
Previc93's Avatar
Just remove old material and tuck into groove.
Snake
Jan 4, 2015 10:51 AM
eyedryve
Aug 6, 2009 08:57 PM
TWGE08
Jan 2, 2009 03:31 PM
FELIXY69
Feb 19, 2008 09:58 PM
apple
Apr 17, 2007 12:27 AM
