OEM radio / subwoofer integration.
Old Feb 19, 2010 | 03:26 AM
accordguyintake's Avatar
im quite sure they take 6.5''
Old Feb 19, 2010 | 03:36 AM
crash001's Avatar
Post pics when completed
Old Feb 19, 2010 | 07:41 AM
drock305's Avatar
Thanks guys..
Old Feb 19, 2010 | 11:50 AM
abcsr2ez4me's Avatar
if you're gonna change speakers you might as well go head unit first.. it'll completely transform your sound! more power, Clearer, crisper, more clean and controlled highs and lows... there is no losing with a H/u
I dont think thats true with the stock HU. Upgrade speakers first, then HU. But of course its a sound SYSTEM so everything should be upgraded. The difference in output from the stock system won't be much, its probably putting out like 15w RMS vs a aftermarket deck putting out between 13w-22w RMS depending on which one you get.
Originally Posted by drock305
I was looking at possibly getting the schosche line output converter thing because I can get it locally... Or should I go ahead and get the RE-Q?? I've never done the oem thing so I don't know how this works. If I use the line output converter can I just put an online switch like you can with a remote wire?
Also, which door speakers and such would you guys recommend? Not satisfied with the stockers...
From my understanding I dont believe LOC have great sound quality, they're just resistors that filter out certain frequencies. You have no ability to change gains or outputs. It's also a mono source as it taps just one channel and filters so you can see the limitations as well. Also to keep in mind the RE-Q and 360 are designed to work with the OEM systems as the newer OEM systems limit bass output. They do so so that when you crank it up the bass doesn't damage the stock paper speakers. The REQ and 360 add bass as you crank it up.
6.5" is the stock size. Just be aware of mounting depths, Honda's are shallow.
Sounds like you're pretty set on the Double-Din. Just droppin the knowledge for future readers
Old Feb 21, 2010 | 01:13 AM
drock305's Avatar
Lol yeah just ordered the pioneer 3100 and two sets of door speakers.. I'll post up some pixxorz when it's intalled.. I'm just excited to put my 12s in te trunk of this puppy.. Thanks for all the info..
Bassguitarist1985
77
Apr 5, 2023 01:58 AM
Judd982
Oct 19, 2013 09:33 PM
Borav
Jun 20, 2012 12:53 PM
potentialFITfan
Nov 4, 2010 06:10 PM
gguest
May 5, 2006 06:31 AM
