Detailed: B1stro's black GD3
Old Mar 1, 2009 | 12:53 PM
  #41
qbmurderer13's Avatar
I'd pick meguiars over mothers any day. Meguiars has a clay kit that comes with lube. Also a lot of people like to clay after washing while the car is still wet. Which is fine providing you have shade so you don't get waterspots. You can also clay it while its dry as long as you have lube. Just wipe it off with the microfiber towel it comes with. If your doing it while the car is wet you won't need to use as much lube and can just rinse off the lube and clay residue or just re wash afterwards. I dry the car, clay in the garage, and then re wash with a rinseless wash such as optimum no rinse, then back in the garage for polishing. But that's cause FL sun is intense and if the car sits outside with water on it for 2 minutes it gets crazy waterspots.
Old Mar 3, 2009 | 03:05 PM
  #42
07fitsport's Avatar
wow that was bad hugee improvement
Old Mar 23, 2009 | 02:16 AM
  #43
doctordoom's Avatar
Supervillain
am i seeing it wrong, or are one or more of that black fit's directional tires mounted in the wrong direction?
Old Mar 24, 2009 | 01:10 PM
  #44
B1str0's Avatar
RubberBabyBuggyBumpers
no your right i like to live on the edge .... ima rebel .. they're fixed now i put them on in a rush when i first got them because i had to go to work the day i got them
Nigh-T Pedri
May 4, 2011 12:28 PM
- tanny2309 - type R -
Nov 3, 2010 02:51 PM
mbemblue
Feb 20, 2010 02:30 PM
qbmurderer13
Jan 9, 2010 12:21 AM
FitVic
Feb 14, 2009 12:59 AM
