Coilover Install **NEED HELP**
Old Jan 11, 2007 | 09:21 PM
07TaffetaFit's Avatar
everything is doing great now, but my passengers side wheel is angled out so I have to hold the wheel to the left for the car to drive straight. You think I need an alignment or what?
Old Jan 11, 2007 | 09:26 PM
It looks like the passenger side wheel is angled outward (toe?) and causes the car to steer to the right if I dont hold the wheel slightly cocked to the left. Should I just get an alignment, or is there some way I can take the wheel off and re adjust this?
Old Jan 11, 2007 | 10:02 PM
phil_qc's Avatar
Yes, you NEED an alignment... Every time you change something on
the suspention, you need alignment. Your toe is out, your camber
is out and if you continue to drive your car, your tires will be out
Philippe
Old Jan 11, 2007 | 10:05 PM
rcantu's Avatar
yep things are crooked. you can try to straighten it yourself but it's not going to be as straight as a pro can do. I think a lot of track guys align the camber on their own. right?
Philippe
Old Jan 12, 2007 | 05:45 AM
azkikersfit's Avatar
yeah phillipe is right, when i changed my springs i had to fix the alignement and the camber so get it aligne man, take it someone who knows. Nice! coilovers by the way
Old Jan 12, 2007 | 08:45 AM
off to get an alignment...
Old Jan 12, 2007 | 11:26 AM
gettinafit's Avatar
Smart decision! Also get the stock honda escentric cam bolts to adjust camber! Unless your coilovers are slotted! I'm Sure you have negative camber up front too not just positive toe!
Old Jan 12, 2007 | 02:55 PM
"Smart decision! Also get the stock honda escentric cam bolts to adjust camber!"
Huh?
Old Feb 4, 2007 | 02:36 AM
rcantu's Avatar
same darn problem occurred today with me! that cursed driver's side. anyhow it's finally in too. gotta adjust height and do the other side.
Old Feb 27, 2007 | 09:47 AM
ewong_kaizen's Avatar
BTW - since I dont own a FIT yet - are the CVs "rezeppa" type (ball and cage) or Tripod Tulip?
Tripod Tulip has lower drag (weaker for racing use) but better plunge...
Many cars use an inner tripod tulip and an outer rezeppa....
Old Dec 5, 2007 | 07:55 PM
jlmspeedjordan's Avatar
I have this same problem right now and hopefully someone can direct me a little. Like the post above the tripod is the three things that have to line up correctly right? once they are in, how do i know they are in? and do i have to jam the axle and hub assymbly to get the axle in all the way, or does it just set in place. my friend with his EP3 said that his fell out and he had to jam it in place..... please help soon.....
Old Dec 5, 2007 | 09:34 PM
  #32
used google
Found this
AUTOS & BOATS : Suspension : Axle CV-Boot Joint -- Parts Installation and Reassembly : DIY Network
Pics J, K, and L show a tripod type inner CV
I have NO IDEA what kind of inner CV is on a Honda Fit (Rezeppa ball or Tripod Tulip)
I like google...
More tech than most wnat to read - but I think its neat
http://www.vtmotorsports.com/pdf/Hal..._CV_Joints.pdf
If the balls fall out of the cage its a freakn mess to get back together..
Old Dec 6, 2007 | 08:28 AM
  #33
WhEreZmYFiT's Avatar
I'm lovin the stance of your car. It looks great with your GF1. I was planning on getting those wheels and was wondering what they would look like. Sweet ride
Originally Posted by 07TaffetaFit
Yeah, I was able to slide it back in... so here are some pics for your viewing pleasure. Enjoy!
Old Dec 9, 2007 | 02:43 PM
  #34
tonyd3773's Avatar
Smile Nice
I love the drop! Plus I was hoping someone would install and post pics on these coilovers....nice addition!
Assuming other then the boot issue it was an easy install?
GD3blaze07'
Old Nov 7, 2008 | 12:42 AM
  #35
jimmyparky's Avatar
Are you suppose to install the driveshaft after control arm is connected or driveshaft first?
I'm installing new control arm, stabilizer, driveshaft. What should be the order of install. Do I need to unhook anything before trying to put in the driveshaft?
I'm kinda worried since so many had problem installing the driveshaft.
Thanks,
James
Old Nov 15, 2008 | 11:43 PM
  #36
poeter's Avatar
My mechanic had exact same problem when installing my Teins.
Left the brake assembly hanging for too long and the cv joint popped out.
Old Feb 22, 2009 | 05:15 PM
  #37
trancedsailor's Avatar
I had to cut the band and put the 3 bearings back in the shaft and put a new band on. Didn't 'repack with grease' though. There was still PLENTY left...
Old Mar 16, 2009 | 05:58 PM
  #38
bokeh's Avatar
I'm dealing with this right now. I've now spent six times the amount of time trying to get this driveshaft back in as opposed to the entire spring swap. Absolutely un****ing believable. I would except this on my e36 but not a Honda.
xTravisxEdgex
Nov 13, 2012 09:02 AM
stylzjhn
May 12, 2010 07:20 PM
Mitsukeru
Feb 21, 2010 07:08 PM
danielg
Jul 9, 2009 09:08 AM
rev_otis_mcnatt@yahoo.com
Jul 21, 2005 02:30 PM
