help with eibach install
Old Apr 15, 2007 | 08:11 PM
Squab's Avatar
I'm in the middle of installing a pro-kit, I 've got three springs done,however; the left front is giving me trouble. I felt the axel come out of the manual transmission or the axel came out of the wheel hub, The right side came out, but I was able to turn the brake rotor and slide it back in, the left side, I'm not able to position the knuckle right and bolt it to the strut. Should I disconnect the ball joint and tie-rod? Any help will do.
Old Apr 16, 2007 | 05:24 PM
Squab's Avatar
Be care carefull not to move the axel when installing the springs, from what I can figure out, the inner driver's side joint has jacked up some how. I can spin the collar connected to the transmission independant from the axel going to the brake rotor,as I turn the collar,I can feel the splines from the axel engage to the transmission,but something is not letting the axel slide in, I'm lacking 1/2 inch to bolt up the strut to the knuckel.
Old Apr 16, 2007 | 06:37 PM
JDMchris.com's Avatar
I run THIS
the 3 bearings inside the boot are not aligned properly. You might have to open it up and re align them.
Old Apr 16, 2007 | 06:43 PM
aznguyen316's Avatar
is it a common issue for the axle to come out during a spring install? heard something like thus happen to another member.. just curious, bout to do mine..
Old Apr 16, 2007 | 08:01 PM
fit4kris's Avatar
Yeah...Not too bad...Just a PITA to put the new straps on with only the car on jack stands
Old Apr 16, 2007 | 08:09 PM
koolkevin1107's Avatar
actually happened to me too. The drivers side axle popped out on my spring install (tanabe gf210). It actually popped out 2x. the first time it fell out i just pushed it and it went back in so i continued to put the spring on the shock. 2nd time it fell out, it took me and my lil brother an hour to get it back in. Just be patient u will get it back in. I wouldn't open the boot since u gotta repack it and everything. SAme thing happened to rcantu but he was patient and got it back in also.
Old Apr 16, 2007 | 08:30 PM
fit4kris's Avatar
I'm an impatient fool! Actually, I was scared I would break it. Not that I can bend steel...But still...Figured the boot would rip. Figured the bearings would pop out and flop in the boot or something. I just figured it would be easier to slide the boot off.
Old Apr 16, 2007 | 10:56 PM
Squab's Avatar
Got it fixed. I took off the dust boot and the axel fell out. I still had the tie-rod and ball joint still attached, about 10 min. and some grunts trying to get the 3 bearings to stay in place, I finally slid it into place. The car rides great.Paid $197 without shipping at Bilstein shocks, Bilstein PSS, Koni, BOGE, Eibach, K&N and other name brand suppliers.
espo79
27
Nov 1, 2019 12:15 AM
sloganmartin
Sep 10, 2012 02:32 PM
sloganmartin
Texas Community
Sep 10, 2012 02:14 PM
thaduke2003
Dec 23, 2011 09:51 AM
thaduke2003
Apr 1, 2011 09:27 PM
