Rotors ?!
Old Dec 7, 2008 | 10:38 AM
SaM01's Avatar
Question Rotors ?!
Hello,
I just had a small question concerning rotors.. I have the 03 Jazz, 1.3 Base Model 175/65R14 .. Are the rotors used the same as in the 07/08 Fit ?! I also heard that old Civics use the same rotors ? if so, which Civic ?! or what model is it ?! Please help..
Thank You
SaM
Old Dec 7, 2008 | 01:03 PM
mahout's Avatar
Originally Posted by SaM01
Hello,
Thank You
SaM
There probably is some commonality but thats not really important. They likely come from the same suppliers so there's little difference as long as they fit. Aftermarket firms like Brembo are tops because the metallurgy of their rotors are superior for stopping hard and often.There are others with good reputations but be warned many auto store rotors are from China and aren't very good specification rotors.
Brake parts are one place where the manufacturer counts !
Old Dec 7, 2008 | 09:48 PM
SaM01's Avatar
So basically, All fit/jazz models have the same rotors ?! Because newer ones has a 205/45R16, mine has a 175/65R14!! does they all fit on the same rotor ?!
Old Dec 7, 2008 | 11:20 PM
micro image's Avatar
R1 Concepts makes a very nice premium rotor for the Fit!
OE Blanks, Slotted, Cross-Drilled, or Cross-Drilled/ Slotted
Old Dec 8, 2008 | 12:57 AM
SaM01's Avatar
is that a yes ?! DO ALL FIT MODELS 2000~TO DATE use the same rotor ?!
Old Dec 8, 2008 | 02:45 AM
kylerwho's Avatar
spoon fed
its a 10.3 inch rotor with a 4x100 bolt pattern.
any honda running this same size will bolt right up to the fit. i think the mid 90 gen civics without abs are the rotors you would want to buy.
Old Dec 8, 2008 | 09:22 AM
just make sure it's the same thickness, too. I will ask R1 about their rotors for the Fit.
Old Dec 8, 2008 | 08:52 PM
SaM01's Avatar
ok, ill be waiting for your reply.. Thanks Again..
Santiad
Feb 8, 2013 01:18 PM
F'it_ImFromTx
41
Jul 19, 2009 09:23 AM
big Fit
Jul 1, 2009 02:38 AM
SaM01
Jun 20, 2009 10:27 AM
p1driftfiend
14
Dec 7, 2008 10:51 AM
