Specific Set Up Question
Old Feb 11, 2009 | 12:10 AM
ASquared150's Avatar
OK, so, I've looked all over this forum and found a bunch of usefull info but am trying to be extra cautious because in the past I've rushed into stuff and gotten burned.
Anyway, I need new springs. Here's the thing(s)
1. I need a pretty mild drop, I have an Eibach Pro Kit now, and it's too low.
2. I would like improved cornering, and though I'm sure this is a result of any lowering spring I'd want the best cornering considering the rest of my conditions.
3. The biggest problem I have is my wheels. They're 16's and they've got a +40 offset. This combined with the drop made for some pretty scary scraping on the walls of my rear tires going over harsh bumps or whenever I had passengers in the back.
4. Though I do like my wheels, if it is the general opinion of anyone responding to this thread that I'm not going to be able to get any results without replacing the wheels, I'll start researching for those - if anybody want's to help they need to be 16's as I'd want to continue to use my Parada Spec 2's.
Thanks a lot in advance for your help guys.
Old Feb 11, 2009 | 12:40 AM
sam21's Avatar
Stay with your wheels,look into Mugen springs with the J's racing adjustable dampers.
Your rubbing and whatnot because of the stock shocks. In lamens terms, they suck. Mugen springs give the least aggressive drop known to mankind, and the adjustable dampers will help your handling.
Old Feb 11, 2009 | 01:00 AM
feared's Avatar
or get coilovers, set it to your desired height and adjust dampening accordingly
Old Feb 11, 2009 | 01:04 AM
What about the stock shocks? Should I look into simply replacing those, or replacing those as well as getting new springs?
Coilovers seem like a good idea but pretty expensive.
Thanks guys keep the suggestions coming, I need help on this one!
Old Feb 11, 2009 | 01:30 AM
sam21's Avatar
That's what I mean by dampers
The J's dampers,just replace your stock shocks.You put your choice of springs on it
Old Feb 11, 2009 | 01:47 AM
Ah, I'm a huge newb when it comes to suspension.
What exactly differentiates Coilovers from just springs and dampers?
Old Feb 11, 2009 | 03:32 AM
Type 100's Avatar
It's all about how they all match up.
If you're replacing your stock springs and dampers piecemeal, chances are the spring rate of the springs and the compression/rebound settings of the dampers aren't built to match one another from the get-go. The best you can do is make an educated guess and experiment with what combo works best (e.g. which will work better with my stock dampers, Swift Sport springs or Skunk2 springs?).
Coilovers by comparison are a set of springs and dampers made to match from day one. They are built from one maker, and have been tuned and designed so that their spring rates and damping are "correct" for that combination. Their main benefit is that the guesswork of matching spring rates and damping behavior is eliminated.
That you can adjust the damping and ride height on some coilovers is a bonus...that said, some of the cheaper coilover sets such as the TEIN Basic Compact set don't have adjustable damping.
HTHs
Old Feb 11, 2009 | 05:03 AM
jagass's Avatar
Actually i have so little knowledge about that...Let me consult other dudes...You better be doing the same thing...
Old Feb 11, 2009 | 09:42 AM
HTHs
Ok I get it, thanks for the info. In terms of basic kits then like the TEIN one you mentioned, what kind of quality/handling upgrade and drop am I looking at?
Old Feb 11, 2009 | 10:01 AM
Type 100's Avatar
Straight off TEIN Japan's website.
?????????BASIC COMPACT / HONDA
BASIC COMPACT - GD3
Recommended ride height drop range:
Front 4.5-6.5 cm (1.77-2.56") / Rear 2-4 cm (0.79-1.57")
Max ride height drop range: Front 4.3-7.5 cm (1.69-2.95") / Rear 1.3-4.7 cm (0.51-1.85")
Old Feb 11, 2009 | 11:17 AM
I'm guessing I'd want to be within the recommended range for the best performance and in the rear the .79 would probably be ok, but the front I would probably want to go with less than a 1.5 inch drop - how's that going to affect the set up?
Old Feb 11, 2009 | 11:40 AM
redrumm's Avatar
if you wanted that drop you might as well keep the stock springs
Old Feb 11, 2009 | 12:39 PM
I'm looking for a mild but stylish drop, plus better handling. I've been looking around more and hearing pretty great things about the Endura-Tech coil overs.
Old Feb 11, 2009 | 08:19 PM
08fithappy's Avatar
Progress RSB for the handling and springs for lowering. U can find both cheap on here used. Or coils same thing find some on here used. I have progress springs for sale i just bought a RSB and now i found a great deal on T1R coils. So i am going with coils and the RSB. I got mine for $700 shiped and they only hace about 2300 miles on them new they go for around $1200 i belive.
Old Feb 11, 2009 | 08:31 PM
kylerwho's Avatar
spoon fed
an easy setup is progress rear sway bar, skunk2 springs, and t1r dampners for a great look and nice handling.
Old Feb 12, 2009 | 12:28 AM
Sugarphreak's Avatar
Push My Button
I might be able to offer some relevant advice;
I run a set of Tanabe GF210's; these springs and the Swift ones (I think) offer the least amount of drop available to the Fit. (about 1.5" in the front and 1" in the rear). However they are remarkably good at giving a much more responsive and better handling drive.
Like you I have fought and fought with rubbing issues, I have taken my car out to autocross and a minor rubbing problem can quickly turn into major issue causing damage to your fenders and tires under those conditions. Here are my basic findings;
-I was using 17" rims on my car, with a +42 offset and 205/40 tires I rubbed on stock suspension
-With a 17" rim & +45 offset I did not rub with 205/40's... however after the springs were installed the rubbing returned.
-With a 17" rim, +45 offset & odd sized 195/40 tires I had zero rubbing
Now, I am planning to pick up a 15" or 16" rim with a +45 offset wheel. I think with a 16" rim and +45 offset mixed up with 205/45 rubber I should be ok... however I will probably go with a 15" rim and 205/50 instead just to be sure. Exchanging rims and tires is time consuming and can have cost implications, better safe than sorry IMO.
Any questions
Hopefully this helps, rubbing sucks! I know lots of people run +42 and even lower offsets with "minor rubbing" under certain conditions; but I use my car for packing lots of stuff and autocross and in both situations I need zero-rubbing.
I also run a 24mm front sway bar, after really looking in depth on how the deflection of the bar behaves I believe any car that is dropped from stock height with benefit greatly from it. With stock height the stock sway bar does not have as much load and probably is sufficient. I did notice a much firmer feel and it seemed to hold better when I was hitting off-ramps and corners on the course after I installed the bar. I like it and would recommend it.
Slasher
Mar 28, 2010 04:28 AM
xonexlifex
Dec 20, 2009 04:30 PM
iLUVYOURGE8
Jun 18, 2009 06:09 PM
Evan_2k
Sep 25, 2008 10:41 PM
