T1R coilover help
Old Mar 10, 2009 | 09:08 PM
Fit-it's Avatar
T1R coilover help
I finally got my coilovers in the mail yesterday from 08Fithappy... Great seller by the way. But I am missing one thing from each of the front coils, do I need them to do the install?
Thanks for looking!
-Matt
Old Mar 10, 2009 | 09:11 PM
mike410's Avatar
Those appear to be the mounts for the sway bar endlinks. I really cant tell from the other installed pic but that should be what those are for, judging by what the stock struts look like.
Old Mar 10, 2009 | 09:51 PM
feifei's Avatar
got mine installed 3 months ago appear that i dont have that thing either
Old Mar 11, 2009 | 02:44 AM
doctordoom's Avatar
Supervillain
i don't have t1r coilovers but i agree with what mike410 says; those look like where you would attach the sway bar endlinks.
Old Mar 11, 2009 | 06:41 AM
Fit-it's Avatar
Bump it up, Need a clear answer on this. These are the BMAX 52s. The pieces seem to be attached to the uni-body not the sway bar... I could be wrong.
Old Mar 11, 2009 | 08:28 AM
SHG_Mike's Avatar
yes they are the front endlink brackets. Though if you bought them new you should have a new design, which has it integrated into the cast housing. Take pics of the set you have and I can tell you if you have an issue. I wouldnt be surprised if they left very important things out though :-/
Old Mar 11, 2009 | 09:24 AM
jdm_gd's Avatar
my t1rs is integrated into the cast housing..i think yours should be too because 08fithappy did have it installed so it must have. if anyone still had that old version it would suck cause you cant lower it all the way ;p
Old Mar 11, 2009 | 11:03 AM
Fit-it's Avatar
Should be able to click this link to see em... On my blackberry right now at work, so I can't load pictures the proper way.
http://i295.photobucket.com/albums/m...DSC_0032-1.jpg
Old Mar 11, 2009 | 11:33 AM
mike410's Avatar
Yeah you dont need that piece you pointed out in the picture. Those have the endlink mount built into the cast housing with and adjustable endlink in it. Circled in red in your picture for reference.
Old Mar 11, 2009 | 12:04 PM
Fit-it's Avatar
Ok next question...How Is the orentation of how the coil is going to bolt to the strut tower(like the washers and misc. Pieces under the strut tower).
Old Mar 11, 2009 | 02:06 PM
jdm_gd's Avatar
you use all the stock washers and top hat.. you have to take off the grey plastic for holding the spring use the top hat and the rubber piece on top of that
Old Mar 11, 2009 | 02:38 PM
Fit-it's Avatar
Gotcha!!! Sweet! Thanks guys! Now how do I give everyone REP points?
Old Mar 11, 2009 | 03:27 PM
TOOL's Avatar
Above each post, sorta to the right you should see where it says "Permalink", to the left of that is that little scale icon, click that to give rep points.
Old Mar 11, 2009 | 08:35 PM
Fit-it's Avatar
Sweet, thanks everyone for there help, everyone minus myself got REP. Im gonna try and do a write on how to install the T1Rs then someone can put it up as a sticky.
Old Mar 12, 2009 | 03:17 AM
jdm_gd's Avatar
werd!!! always down to help when it comes to suspension work lol..
Old Mar 12, 2009 | 04:46 PM
Fit-it's Avatar
You think letting the springs settle over night (installing them on friday night) will be long enough so I can get it aligned on saturday? They are used coilovers, don't know if that would make a difference.
feared
39
May 5, 2015 09:18 PM
chinkieboy
Washington Community
13
Jan 14, 2012 11:42 PM
Fitfreak07
22
Jul 14, 2011 08:44 PM
Squad808 Fit
Sep 30, 2009 02:16 AM
igarage
Jul 30, 2008 12:02 AM
