ultra racing front lower brace (pics)
Old Mar 10, 2009 | 10:36 PM
redrumm's Avatar
well as some of you may or may not know the ultra racing lower brace does not fit on the US fits for some reason.
but with a little fab this will work. i will update when i get another chance to work on it
1. here is the bar with the bracket that mounts the brace
2. here are the mounting points on the bracket(circled in red)
3. install the bracket with the small size first. ( long side facing the front and small side facing the rear)
3. here is where it does not bolt up because it is a bit longer. So i marked the spot and will drill a hole. Next i will drill a hole on the bracket and put in a new screw. Easy fix.
Keep in mind this was not bolted up so it will sit back a little further....... about this much
Old Mar 11, 2009 | 04:56 PM
grtpumpkin's Avatar
What does it use at the other end for a mounting point, the control arm bolt? And these brackets, one bolt secures the bracket to the car and the other secures the brace to the bracket correct? Will you be supplying modified brackets or is that up to the buyer? How about a template for where to drill the body for a proper fit? sorry about all the questions, I probably shoulda just PMed you. PS How much$$ ?
Old Mar 11, 2009 | 06:40 PM
redrumm's Avatar
the bracket comes with the bars.
im actually going to be making a plate and not drill a hole.
i will show you when i get a chance to make it.
pmd
Old Mar 13, 2009 | 02:11 PM
Fit-it's Avatar
You got a PM
Old Mar 13, 2009 | 02:49 PM
kylerwho's Avatar
spoon fed
that is pretty awesome.
glad other people have fabrication skills.
Old Mar 13, 2009 | 03:43 PM
redrumm's Avatar
GOT 3 lower rear bars for sale in stock and ready to ship
if anyone is interested PM ME
Old Mar 13, 2009 | 03:44 PM
redrumm's Avatar
Originally Posted by Fit-it
You got a PM
didnt get anything bro
Old Mar 13, 2009 | 05:06 PM
kylerwho's Avatar
spoon fed
pm me with prices on both pieces please.
bump for good guy selling viagra for the fit. fit is stiff!!
Old Mar 13, 2009 | 05:22 PM
redrumm's Avatar
thanks man.
i got my fender bars in
PM coming your way
Old Mar 16, 2009 | 12:52 PM
redrumm's Avatar
the last few pieces to the puzzle.
Old Mar 16, 2009 | 01:11 PM
Fit-it's Avatar
Do you cover any warranty on your product? I mean they seem to look pretty legit.
Old Mar 16, 2009 | 04:34 PM
redrumm's Avatar
yes. lifetime warranty and trade in value
Old Mar 17, 2009 | 02:19 AM
kylerwho's Avatar
spoon fed
did you figure out installing the front one yet?
Old Mar 17, 2009 | 09:17 AM
redrumm's Avatar
i havent gotten the chance to mess with it. i think i found the brackets i need to bolt it up.
Old Apr 3, 2009 | 09:15 AM
redrumm's Avatar
update:
going to put on fender braces, progress bar w/ panducky bolts. will get pics up later today
and finally going up the street from the shop to see if i can get some brackets for the lower brace
Old Apr 4, 2009 | 02:19 PM
ekonetics's Avatar
Take some pics of the install for the fender braces.
Old Apr 4, 2009 | 08:38 PM
redrumm's Avatar
I will man. think im going to start on it tonight while i have sometime. im still at work but i get out in 15min.
little late night session.=)
Old Nov 14, 2013 | 11:14 PM
Lance's Avatar
Any update on this?
I am now the owner of one of these and am not looking forward to this install. If you figured out what when where and how to make it fit can you you please help out this thread. This is a long shot since how much time has gone by since activity.
Old Nov 15, 2013 | 12:27 AM
kylerwho's Avatar
spoon fed
owner of the front fender braces? this might give you an idea of where it goes.
Old Nov 16, 2013 | 06:07 PM
Lance's Avatar
no its
Its the 4 point bar that goes under the car not the fender . I need to know how to get that cued up for install. Last said drill the brace and a hole in the car. I need to know what size hole it needs to be and what length from either end it should be in considering once the front bolts hug the final resting position could change. Also does it rub, on a pic I found on ebay of the bar installed it looks like it crosses over and could be touching . Anyways. I don't like knowing this is a issue and no one ever finished the resolution.
