Progress sway bar hardware . . .
Old Feb 27, 2010 | 12:20 AM
FitGD4's Avatar
Attention!!
the pinch on the new hardware on this post is wrong!! The bolts that are provided by Progress are a 1.25 pinch, not 1.50. I ordered the 1.50 hardware and the nut would not fit. So, if you order the hardware or buy it from a hardware store you need a button head allen 10M x 30 1.25. If you want to use the nuts provided by Progress.
Old Feb 27, 2010 | 09:00 PM
Daemione's Avatar
It's pitch, not pinch.
And I wouldn't say it's "wrong", since that is the thread pitch used in the old panducky hardware kit, which is what I was reproducing. I was unaware that the Progress ones are different, since I didn't reuse them (nylock nuts should be replaced every time they're removed). But for everyone starting off with the proper hardware, using the Progress nuts is an option - so good info, thanks!
Old Feb 27, 2010 | 09:48 PM
FitGD4's Avatar
I thought you were using the nuts from the progress kit. I tried the Panducky link and it didnt work. I ended up ordering from Fastenal.com. Now I am having a hard time finding the nuts that will work with my Fastenal bolts!!
Old Feb 27, 2010 | 10:44 PM
Fitting's Avatar
Sadly Panducky went out of business a while ago.
Most of us that bought new hardwares bought new bolts and nuts.
Mine came from Acehardware.
Old Mar 10, 2010 | 04:39 PM
OneStopCustoms's Avatar
Originally Posted by kylerwho
uh..... guys you should just weld the bar on and forget about that hardware crap. that is what i did and i hear no noises and my springs have set properly with no interference from bolts.
Kyler, finally someone welds it on. However, welding a piece of angle iron to the stock bar would had done the same effect of having a roll bar as it would stiffen the entire rear lol
Old Mar 12, 2010 | 03:47 PM
Daemione's Avatar
Have fun figuring out how much roll resistance you're adding by doing that . . . Bars are tuneable and/or swappable. Welds, not so much.
Old Mar 13, 2010 | 12:21 AM
xm8's Avatar
xm8
Button Socket Cap Screws may not cut in to the rubber seat but the Button Socket Cap Screws still push up on the rubber seat.
Link to The Button Socket Cap Screw:
M10-1.5 x 30mm ISO 7380 A2 18-8 S/S Button Socket Cap Screw | Product Details | Fastenal
Old Mar 13, 2010 | 12:50 AM
Daemione's Avatar
I'm not sure what your point is - they can push up on the rubber seat all they want, as long as it doesn't damage them or affect the spring seating.
Old Mar 17, 2010 | 02:29 AM
xm8's Avatar
xm8
Does the Button Socket Cap Screw push up on the spring and change the spring angle?
Old Mar 17, 2010 | 07:03 PM
Antpwny's Avatar
Do you guys think a 24mm would work or would it be too short?
Old Mar 17, 2010 | 08:25 PM
Daemione's Avatar
Nope, the spring is unaffected.
And for what it's worth, stock springs are unaffected by the original progress hardware as well - the difference is that the rubber mount becomes damaged.
Old May 5, 2011 | 08:08 PM
  #32
jondotcom's Avatar
FYI, ordered this bar for a GE and rec'd button-head bolts with it!
Old May 7, 2011 | 03:45 AM
  #33
solbrothers's Avatar
Originally Posted by Daemione
That'd be fine if I was 100% sure I'll never want to return the car to stock to sell it. I also like to keep my options open when it comes to suspension upgrades . . . e.g. when I get coilovers in the near future, I may not want the bar on there at all - depends on what the balance is like.
definitely keep the bar on there.
Old Mar 13, 2012 | 12:07 AM
  #34
dustinb's Avatar
I just received my new progress sway bar for my 07 GD3 Fit. I was pleased to see that Progress is now including button socket screws and nylon nuts with the bar.
Old Oct 2, 2012 | 03:05 PM
  #35
IAmLumberjacked's Avatar
When I was looking for it, a search came up with the answer pretty easily. User sl0wp0k3 had the answer in a thread discussing the old Panducky hardware kit.
6 button socket screws m10x1.5x30
6 m10 washers
6 m10x1.5 nylock nuts
So Daemoine have you installed this replacement hardware yet? How would you describe the difference? Anything helps.
Thanks.
Coaster1
Jul 12, 2019 07:09 PM
Hocker
13
Sep 7, 2010 11:25 PM
Darkstars
Mar 22, 2008 08:40 AM
lilcat
California - Bay Area Community
Mar 11, 2008 09:36 PM
