T1R Spec-S Dampers
Old Nov 25, 2009 | 11:58 AM
JCrimson's Avatar
thats my problem exactly. with my skunk2 springs on oem shocks. there was less body roll. even thought the t1r springs are supposed to be better. Im thinking about swapping but i just got an alignment yesterday grrr. someone put your skunk springs in the t1r dampers and tell me how magical it is. i wanta know!
Old Nov 25, 2009 | 04:45 PM
Lightarrow's Avatar
Did u cut the (yellow)stopper when u had the skunk2 springs and stock dampers ? I didn't and im starting to think that was why it was almost no body roll.
Old Nov 26, 2009 | 01:10 PM
JCrimson's Avatar
no i didnt cut them. i used them as they were. you think we should? jason from A-J, CHIME IN PLEASE!
Old Nov 26, 2009 | 03:05 PM
Lightarrow's Avatar
Well the DIY on this site for springs says you should cut the stoppers and leave 3/4 of it on the stock damper so you won't bottom out.
Since we didn't cut them, we must have ridden on the stoppers, hence the harsh ride and pretty much no body roll. (this is just speculation i am no mechanic).
Maybe we should buy a sway bar to solidify the crap of that suspension :P
Honda Fit DIY and Reviews by smeister13: DIY: Install Progress Rear Swaybar for Honda Fit
I'd also like to say i had a very good experience with A&J, they were fast to communicate and the shipping was fast ( 5 days from BC to Quebec).
Old Dec 16, 2009 | 05:50 PM
customfit's Avatar
Salut aux Boys du Québec !!
I have Eibach pro-kit springs for the summer but until now stock dampers. I am seriously thinking of ordering the T1R damper and spring combo and was also curious to compare the two brands of springs with upgraded dampers. I don't know witch ones I would try first ?? Probably the T1R as from what I read they seem to be a bit stiffer (at least in the back) and I'm looking for a more track-oriented setup.
Maybe next summer, cause for now I returned to stock to clear the snow !!
Old Dec 16, 2009 | 08:17 PM
Lightarrow's Avatar
Up till now the T1R are great (springs + dampers combo) i found that they gave me more body roll than Stock dampers + Skunk2 springs. But that may be because of uncut stoppers.
Moi jlai laissé lowered pour l'hiver.. jsuis tanné de toujours switcher pis le clearance est pas pire quand j'enleve le lip kit de ma sport. J'marrange pour pas suivre des trucs qui dump des grosse turd c tout :P
Serieu je trouves qu'il y a bcp de body roll avec les T1R mais j'ai rien fait de trop extreme. Moins que stock mais quand meme assez.
Old Dec 20, 2009 | 08:17 PM
wdb's Avatar
wdb
Subscribed for interest. I'm looking to improve the car in daily driving situations and not lose much if any comfort. I was able to do it in my STi so I hope it's possible with the Fit too! The T1R's appear to be the best alternative for my needs so far.
Old Dec 20, 2009 | 11:04 PM
Lightarrow's Avatar
Well i dunno about 09 fits ( if that's what u have) but i have to say it's still pretty harsh, even at the softest level. It's certanly the softest alternative out there. When going over small bumps its allright but bigger bumps are quite noticeable.
Old Jul 18, 2010 | 04:51 PM
pokems23's Avatar
June 2007 3rd Place Fit of the Month Winner
I'm having trouble tightening bolting on the top of front dampers. Do I need to use an impact wrench in order to tighten it? My kung fu grip isn't strong enough to keep strut from spinning while I tighten bolt.
Old Jul 19, 2010 | 11:41 AM
GD3_Wagoon's Avatar
take your Fit off the jack stands then try tightening it again. that worked for me.
Old Jan 18, 2011 | 02:39 PM
AJR Jay's Avatar
If you're looking for comfort and performance, I think considering the T1R is a good choice. You can compliment the dampers with any lower springs for the GD3.
Secondly, it gives you best of both worlds, you can maintain both comfort and performance with some minor adjustments.
Regards,
Jason @ AJR
07FitSBOM
Mar 8, 2011 06:10 PM
Lightarrow
Mar 2, 2010 09:16 PM
jdmfit88
Mar 3, 2009 01:41 AM
Halcyon
Dec 21, 2006 10:36 PM
Halcyon
Aug 21, 2006 11:15 PM
