Ground Control Coilovers? Any Good?
Old Feb 5, 2010 | 04:27 PM
ruelthewOrld's Avatar
I want to lower my gd. im lookin for comfort driving, stiff, no bouncing and makes a clean drop. im thinkin about ground control coilovers and was tryna see if anybody new how they ride. but i am willing to hear other suspension set ups. let me know whats good.
Old Feb 11, 2010 | 08:01 PM
DOHCtor's Avatar
The only think i know about Ground Control Coilovers is how much they kick ass on a Neon!! They also should be excellent on the Fit but i don't know!
Project Dodge Neon: Part 1 - Project Cars - Sport Compact Car Magazine -> For more infos...!
Marko!!
Old Feb 12, 2010 | 03:08 AM
clay7160's Avatar
I had them on both of the vehicles below and loved them....nothing bad to saw....
1st of all they come with eibach springs which are great..stock stocks will wear down faster if dropped really low....but even blown stock shocks do not ride bad in my opinion with the ground controls.........also when installing, make sure you use the o rings between the coilover sleeve and the shock body....it will stop rattling or squeaking....and if they is some movement or play....go to local hardware store and buy a rubber type material to make the sleeve fit tight against the shock body....on my yellow mazda i used an old bicycle tire inner tube cut up and wrapped it around the shock body to take out any play..........shoot some pics after you get them.....
Old Feb 12, 2010 | 12:41 PM
DatFIT's Avatar
Mostly lots of autocross or track people uses them... mainly use if youre putting your own coilover.
Old Feb 12, 2010 | 02:28 PM
dela's Avatar
i recommend getting some adjustable shocks if u get the GC sleeves... any major increase in spring rate with stock shocks will give u a bit of a bounce due to them being oversprung...
Old Feb 14, 2010 | 06:20 PM
Thanks a lot. I am new to this so i can use any help. Good lookin out guys
bunz559
Aug 27, 2015 01:03 AM
jazz_do_it
May 8, 2010 10:11 PM
99dx
Mar 18, 2009 04:33 PM
emmad00d
26
Aug 30, 2008 10:29 PM
F'it_ImFromTx
19
Apr 10, 2008 05:17 AM
