Coilover help!!!
Old Mar 7, 2010 | 04:46 AM
chinkyy's Avatar
Coilover help!!!
i have tein basics which are really comfortable for coilovers but dont go as low as i need to. i've heard that if you change the springs it MIGHT get me lower. if this is true what springs do you recommend i switch to to get lower?
Old Mar 7, 2010 | 06:28 AM
dela's Avatar
eibach makes good coilover springs...
what are your spring diameters/spring lengths/spring rates?
to go lower you can lower the spring rate or shorten the spring length
Ground Control Suspension Systems - Your source for the best in suspension parts and accessories.
Old Mar 7, 2010 | 11:11 AM
Texas Coyote's Avatar
I am installing Swift Mach springs today.... Twenty nine years ago I went for the extreme low look on a VW pickup and it ended up being the dumbest thing I have ever done to a car,,,, Save yourself a lot of headaches and expense by not going for a look that will mess up your ride and instead focus on improving the ride and handling..... I really like the slammed look a lot but I like being able to drive my car without having to worry about tearing off the lip and bumper or busting oil pans and my back.
Old Mar 7, 2010 | 06:19 PM
chinkyy's Avatar
maybe its just one of those things i have to go through and learn from =) thanks for your concer though.
this is the link to tein's website for my coilovers.
HONDA FIT
which springs do you think can go lower than those?
Old Mar 7, 2010 | 06:43 PM
dela's Avatar
well... is there any way you can go out and measure your springs unloaded? length and diameter? maybe contact a tein distributor?
that would help in finding replacement springs that would fit the coilovers...
my guess is that they're 2.5" diameter... dunno about the lengths
revd34
Jan 9, 2021 02:03 PM
im the fit
Mar 19, 2009 12:37 AM
Kurse
13
Jan 22, 2009 11:58 AM
sl0wp0k3
Dec 11, 2008 04:42 PM
fung88
Sep 12, 2008 08:30 AM
