Weird noise from the rear springs
Hello, since installing my Tein S-Tech's and Progress RSB, there has been a weird creaking noise. I removed the RSB, thinking it was the hardware, but the noise is still there. I even replaced the rear springs w/ the stock ones, but still the same noise. Anyone have some insight on this? Its worst at about 10-20 mph over bumps. Thanks in advance!
Thanks for the reply. Yeah, I retightened the bolts on the lower end of each strut. Maybe check the top nuts to make sure they are tight? I haven't touched them tho....
I found this old thread and will try to tighten the bottom up some more.
https://www.fitfreak.net/forums/fit-...unk-noise.html
danger69
Jan 6, 2010 09:46 PM
NBPturtle
May 29, 2008 09:52 AM
arsim
Sep 17, 2007 05:41 PM
