Squeeking/clinging/creeking noise from rear suspension
Old Dec 28, 2009 | 01:22 PM
danger69's Avatar
This is kinda odd, that once i put on my new wheels I hear some squeeking noise from the my rear suspension. The noise only happens when I go over a bump or up my drive way when backig up. It sounds like my sway bar though. I am using the progress bolts and I can see that it tore into the rubber cover around the springs. Could the screw be rubbing against the spring which makes my bar a little bit loose? So when I take a turn the swaybar twists a little making it tap on the rear suspension to be making the noise? This is my only conclusion that I have to get the flusher bolts. My springs/shocks are all stock.
edit: Found the answer possibly from another fit freak member. I will let everyone know if it is the same problem.
https://www.fitfreak.net/forums/fit-...-sway-bar.html
Old Jan 6, 2010 | 08:33 PM
danger69's Avatar
Yup it was the bolts from the RSB rubbing against the springs. I changed them out to the socket heads one and the noise has diminished but not totally. I'll see what happens when I get my coilover in.
Old Jan 6, 2010 | 09:46 PM
redrumm's Avatar
coilover should have more clearance. alteast on mine it did and it doesnt really make any noise
DrKelso
Aug 30, 2012 07:19 PM
flipwidwings
May 12, 2012 07:41 PM
BallerStatus
Jun 9, 2011 05:44 PM
danger69
Oct 12, 2010 10:14 AM
Henry
Aug 4, 2005 08:31 PM
