Adding suspension bars; what order??
Old Aug 26, 2012 | 02:50 PM
dtfdanyo's Avatar
if it's rusty, I WANT IT, I NEED IT
fixed for you bb <3
Old Aug 26, 2012 | 03:21 PM
Originally Posted by joey_fits
Op listen to mike410b he has 2 of the most legit,rare-jdm aesthetics oriented parts on his fit therefore...... I'm just a dumb that's going to try and convince you that a set of bilstein coilovers would be a better route than springs and bars,performance "feel" wise. Some cars greatly improve with bars. The fit is small and relativly stiff from the factory and wont benefit as much as say a galant would. Not a bad thing (buying bars) just not a miracle but a small piece of a greater puzzle.
Galant would most likely benefit less from bars than a Fit would. While the Fit is quite stiff down low, it can still improve. The Galant is impressively stiff.
As for Bilstein coils vs. bars and springs, I wouldn't do either. The Bilsteins will only function if the car is set up correctly, ie good alignment settings (non-OEM) and proper corner balancing. I doubt either springs/bars or improperly set up Bilsteins will improve the handling at all.
As for my owning 'JDM' appearance parts, they are what I've wanted the longest and they're tough to get a hold of, I saw an opportunity and I took it.
Old Aug 26, 2012 | 03:30 PM
joey_fits's Avatar
I never said "improperly set up" where'd you get that? Also I just said galant as a generic car. I'm not up on all mitsus .. and I like your mods don't get sad. Never said I didn't.
Old Aug 26, 2012 | 03:44 PM
I said improperly set up because outside of JCrim and 555 I doubt a single member of this site even considered getting their car corner balanced after their coilovers were installed. Yet they claim huge handling increases, which are stupid unlikely.
Old Aug 26, 2012 | 04:04 PM
zilla8's Avatar
some of the post here just do not make sense
I installed Swift springs and Progress RSB along with upgraded 205 tires.
This made a night and day difference from stock handling.
I'm sure Bilstiens would do the same without corner balancing or any fancy set up.
If I were adding braces I would start with the Cusco lower and go from there.
Old Aug 26, 2012 | 04:29 PM
Obviously tyres (however I doubt they were anything special, thus the differences minimal) and an RSB will make a difference. However your springs likely did nothing.
I'm sure Bilsteins would make no legitimate difference, just a butt dyno reaction.
Old Aug 26, 2012 | 06:24 PM
zilla8's Avatar
You gotta be kidding me Mike lol
Bilsteins and Swift springs not making a difference compared to stock give me a break.
Old Aug 26, 2012 | 06:34 PM
Wanderer.'s Avatar
Corner balancing is just fine tuning, not corner balancing a car with coilovers does not negate the handling gains of the components, which it kind of looks like you're saying here?
Old Aug 26, 2012 | 06:36 PM
It won't negate but it makes a huge difference. Without corner balancing, cars on coils will handle all wonky and stuff. This is from my experience where my second set of coils was definitely not CB'd and aligned to OEM specs.
Old Aug 27, 2012 | 01:26 AM
joey_fits's Avatar
Ps mike I'm corner balanced and love my coils
Aussie
Jul 20, 2018 12:44 PM
7cain
Sep 7, 2012 12:06 PM
BIGSAMV
Sep 9, 2011 08:25 PM
Lek
Jan 26, 2010 04:26 PM
gripfaction
Car Shows, Events, and Racing
27
Jan 12, 2009 02:29 AM
