Least amount of drop with the best ride?
Old May 16, 2013 | 03:02 PM
TPColgett's Avatar
HP > at least from my experience
Old May 16, 2013 | 03:04 PM
Bull's Avatar
This is great info . . . so here's a wrench to throw in the mix. I just put some wheels & tires on the Fit. 15x7 +31 with 195/55/15. The wheels are damn near dead flush and look perfect in my opinion. Right now at stock height I've got 2.0-2.25" of tire to fender lip clearance up front and 1.75" of tire to fender lip clearance out back. Am i setting myself up for RUB with any of these spring options? And no, I'm not interested in different tire sizes. I'm not making this easy, am I?
Old May 16, 2013 | 03:09 PM
TPColgett's Avatar
Anything lower than +45 CAN rub, specifically in the rear. But, your running OEM size tires... Honestly, as long as you stick to Swift's or Progress or another spring that does not drop it too low, I think you will be OK.
I run 225/45/15's on 15x8 +25.... On coil overs with LOTS of camber
You can always do some comparisons here: Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
PS: I used to run 205/50R15's on 15x6.5 +40 Rota's with Swift springs as my every day setup with -1.5 camber up front and NEVER rubbed. You only stick out 0.4mm/0.2 inch more than that setup, so throw on some camber bolts up front for a little extra insurance and make sure to set the toe to zero!
Old May 16, 2013 | 03:24 PM
Bull's Avatar
I guess the real question is . . . Is .50-75" tire to fender clearance enough for suspension compression under normal driving conditions?
Old May 16, 2013 | 03:36 PM
TPColgett's Avatar
Good question... There is really only the one way to find out :/ The Swift springs being linear and a bit firmer would be a safer bet as they would likely compress less... but that indicates a trade off in comfort... and around and around it goes LOL
The rear is what's actually hard. If you rub, it will be back there with a load in the car on bumps. In the front, a single set of camber bolts for at least -1.0 camber and toe set to zero and I bet you will be fine. Actually should have improved tire wear as well as handling
atorni
152
Jul 6, 2015 01:54 AM
Praxis
Mar 11, 2015 10:54 AM
06Jazz
Aug 10, 2011 08:46 AM
Zivman
May 2, 2011 11:37 PM
wait4thefit
Jul 17, 2008 03:17 AM
