Rear Disc - Seriously Trying to Get OEM DIY Sorted Out
Old Aug 27, 2014 | 12:42 AM
Rollerboots666's Avatar
Interesting......
Old Aug 27, 2014 | 04:16 AM
kylerwho's Avatar
spoon fed
I wish jpax still had his fit around so I could take some measurements. Let me dig through my saved files to see if I have that length or even pictures.
Old Aug 27, 2014 | 09:37 AM
jibberjabbs's Avatar
Apexanimal, Good job on getting this rolling. This bracket could make rear discs much more attainable. Whats the word on these fitting the GE?
You have probably seen this already, but fellow member Steven Hung has the FastBrakes rear kit on his GE.
https://www.fitfreak.net/forums/2nd-...onversion.html
Also these pics are from a previous attempt , Thread: https://www.fitfreak.net/forums/2nd-...prototype.html :
Old Aug 27, 2014 | 10:48 AM
apexanimal's Avatar
anything you have would be helpful
i haven't asked about the ge... once we get the gd going, i'll probably pass that project onto the next person since i don't have a ge and don't have a lot of time to work on all of this - i wouldn't be able to test it and would just end up being a go between...
Old Aug 27, 2014 | 06:39 PM
apexanimal's Avatar
brake lines: so i found that the corresponding stoptech rear ss brake lines are just under 19"... with the rearward placement of the caliper and its port, i don't think its going to be quite long enough to get to the stock hardline...
i was looking at pictures of the t1r kit, and part of the kit included a new ss brake line set as well as a section of hardline... we need to find out how long the combination is in order for me to figure out what brake lines we need...
parking brake cables: i could use some help to find out what other hondas have the style of parking brake cable as seen below in the pictures... this will help me figure out the correct part number once we figure out the length of the cables that are needed...
the integra cables are between 64-66", and it's reported that the ge cables are between 69-70"...
Old Aug 27, 2014 | 09:22 PM
kylerwho's Avatar
spoon fed
ok so jpax had fastbrakes do his however he seems to remember using an 87 acura legend coupe parking brake cables. Rockauto has the coupe lines being around 70 1/2" and the sedan lines being around 74"
Old Aug 28, 2014 | 10:20 AM
apexanimal's Avatar
i looked at the legend but didn't go that far back - good info!
Old Aug 29, 2014 | 08:58 PM
apexanimal's Avatar
so i got under the car today to measure the brake lines out for the rear...
i don't think the 19" replacement lines i found are going to be adequate... i think we're going to need at least 21" and i'll probably try to get 23" to be on the safe side...
this length will only go to the first connection and won't replace the soft section... that would require at least another 4" of brake line...
it will be up to you in terms of what brand of ss lines you go with, but i'm trying to stick with a line that has a clear sleeve over the braided ss to prolong its life...
Old Sep 2, 2014 | 12:12 PM
apexanimal's Avatar
i'm at my wit's end with these brake lines...
i'm going to wait until i have the brackets and calipers so i can accurately measure the length that we'll need...
Old Sep 10, 2014 | 06:44 PM
apexanimal's Avatar
just got word that the first brackets are finished... they will be shipping to me soon...
here is my plan:
1. once i hear that they have shipped, i will be ordering the rotors, pads, and calipers
2. test fit the brackets with rotors, pads, and calipers to ensure that fitment is good
3. if fitment is good, measure needed lengths for brake lines and parking brake cable
4. order brake lines and parking brake cable
5. install everything
6. i profit
7. finalize parts list for everyone
8. everyone profits
Old Sep 10, 2014 | 09:28 PM
xxryu139xx's Avatar
here is my plan:
6. i profit
8. everyone profits
make a DIY!
Old Sep 11, 2014 | 04:40 PM
  #32
apexanimal's Avatar
the brackets have been shipped and are on their way from WA...
Old Sep 11, 2014 | 10:19 PM
  #33
apexanimal's Avatar
ordered:
-centric premium rotors
-stoptech street performance pads (to match my fronts)
-centric reman semi-loaded calipers
Old Sep 12, 2014 | 08:56 PM
  #34
apexanimal's Avatar
I need some help looking for the part number for the two bolts that hold the caliper bracket onto the spindle... i'm having a hard time tracking it down...
for a 1997 acura integra, rear caliper bracket mounting bolts...
who can find it?
Old Sep 12, 2014 | 09:01 PM
  #35
kylerwho's Avatar
spoon fed
90107-SD2-931
acura part number
10mm x 47mm
Old Sep 13, 2014 | 09:03 AM
  #36
apexanimal's Avatar
^ badass...
Old Sep 13, 2014 | 11:20 AM
  #37
De36's Avatar
I believe the cable that FastBrakes uses is from a newer civic.
The hard lines are easy enough made custom, you can rent the flare tool from any parts place and splice in line. Cheap and easy.
Old Sep 14, 2014 | 11:01 PM
  #38
apexanimal's Avatar
i'll just leave this here for now...
Old Sep 15, 2014 | 12:19 AM
  #39
kylerwho's Avatar
spoon fed
Those look good. Curious to see how they bolt up.
Old Sep 16, 2014 | 12:27 AM
  #40
swade's Avatar
Excited to see this come together. You can always have custom SS lines made. Or get some from summit in different lengths, I think all-star performance or something makes bunch of lines that would work in different lengths.
swade
