FIT-Vendor Sponsored Group Buys and Sales Organize group buys to get discounts. Only Forum Sponsors may post group buys in this sub-forum. Forum Sponsors will have "FIT Vendors" in their user title and have gone through a screening process by FIT Freak staff.
Race Ramps - Lightweight Ramps for DIYers
Old May 25, 2011 | 05:17 PM
Bean_Garage's Avatar
Former Vendor
Made in the USA are these lightweight ramps to help you work on your car safely. They are high quality and the best ramps you can buy. For the true enthusiast that needs a better alternative than a conventional car jack.
Bring them to your next car meet or race!
Race Ramps 56" 2-Piece Lightweight Ramp
$235 including shipping for a set of two
56" Race Ramps are ideal for low ground clearance vehicles with tires up to 10" wide. With an incline of only 10.75 degrees, they lift your car up 8" and hold up to 3,000 pounds per set while weighing only 10 pounds per ramp. They are built in one solid piece, making them durable and sturdy. Like all Race Ramps products, they will not slide across a garage floor, dig into an asphalt driveway, or scratch or otherwise damage a cement or painted floor. They can be used on grass, dirt, or almost any other flat surface, and they will never rust. Race Ramps come complete with straps for easy carrying and storage. Set of 2, 4 Pieces Total.
After you have your car secured on the Race Ramps, you can remove the back "ramp section" and have access from the side of the car as well as the front and rear. Each ramp can still be stored as one piece (or two if you wish).
  • Lightweight Construction
  • Will not Scratch or Mark any Flooring
  • 56 Inches Long, 12 inches Wide
  • 8 Inch lift Height - Works with many other products!
Race Ramps 56" Lightweight Ramp
$215 including shipping for a set of two
56" Race Ramps are ideal for low ground clearance vehicles with tires up to 10" wide. With an incline of only 10.75 degrees, they lift your car up 8" and hold up to 3,000 pounds per set while weighing only 10 pounds per ramp. They are built in one solid piece, making them durable and sturdy. Like all Race Ramps products, they will not slide across a garage floor, dig into an asphalt driveway, or scratch or otherwise damage a cement or painted floor. They can be used on grass, dirt, or almost any other flat surface, and they will never rust. Race Ramps come complete with straps for easy carrying and storage. This is for a set of two ramps.
The Chart below will help you determine if 56 Inch Race Ramps will work for your vehicle:
YouTube - ‪Race Ramps - Using Your Ramps‬‏
Race Ramps 67" XT Lightweight Ramps
$299 including shipping for a set of two
Race Ramp XTs are ideal for low ground clearance vehicles with tires up to 12” wide. With an incline of only 10.75°, they raise the car up 10” and hold up to 3,000 pounds per set while weighing only 15 pounds each. They are built in one solid piece, making them durable and sturdy. Like all Race Ramps products, they will not slide across a garage floor, dig into an asphalt driveway, or scratch or otherwise damage a cement or painted floor. They can be used on grass, dirt, or almost any other flat surface, and they will never rust. Race Ramps come complete with straps for easy carrying and storage. Set of two.
Race Ramps Rollups
$160 including shipping for a set of two
Roll-Ups are designed to be used in conjunction with 56” or 67” Race Ramps or 40” Sport Ramps. They raise the opposite end of the vehicle up 4”, enabling you to complete more difficult tasks such as changing the exhaust. Roll-Ups can also raise the front or rear of the car to allow the use of a standard floor jack. And at 14” wide, they can be used with tires up to 12” wide. They weigh only 4.5 pounds each and are small enough to fit in the trunk of most sports cars. Set of 2.
Race Ramp Product at Bean Garage
We have access to the rest of Race Ramps products, so feel free to ask for a price quote on anything you see on their website!
SilverEX15
May 21, 2017 10:30 PM
jeng
Aug 24, 2016 11:56 AM
hogwylde
Mar 19, 2015 01:17 PM
j1nNju1c3
Sep 17, 2011 02:27 AM
GD3_Wagoon
Nov 11, 2008 12:25 PM
