The OFFICIAL Fit Shoes Thead! (Lug Nuts Included!)
Old Jan 23, 2010 | 06:13 AM
  #821
hondaFORlife's Avatar
Black3sr -
I had a friend that works/owns a bodyshop.... he painted the wheels the same code as the body.. taffeta white =]
Matches perfectly. . I wanna get the red Honda emblems for the center caps. .
Old Jan 23, 2010 | 07:28 AM
  #822
Black3sr's Avatar
Originally Posted by hondaFORlife
Black3sr -
I need a friend with body shop. I have blue emblems on my stock wheels.
Old Feb 7, 2010 | 02:14 AM
  #823
Hootie's Avatar
Wheel: Konig Quiz
Offset: +40
Color: Black with Polished Lip
Tire: Dunlop SP31, Yokohama Avid V4S
Size: 195/55R15, 205/55R15
Lowered?: No
If Yes, What Setup?:
Front Rubbing: No, no*
Rear Rubbing: No, yes*
Comments: Wider track and no rubbing whatsoever with the SP31s. With the Avid V4Ss the vehicle ride height is raised slightly, no rubbing is experienced with a 170lb driver in the vehicle; however add one 250lb passenger rubbing will occur when hard turns and bumps are experienced on the passenger front with untucked fender liners and both rear.
* With 205/55R15s
PHTO00582-1.jpg?t=1265526667
Old Feb 7, 2010 | 06:52 PM
  #824
555sexydrive's Avatar
Wheel: VR RE30
Size: 16x6.5 65mm center bore, using Rays 65 to 56.1 hub rings
Offset: +45
Color: Hyper Bronze Premium
Tire: Yokohama Neova AD08
Lowered?: Yes
Lugs?: T1R Chromoly
If Yes, What Setup?: Honda Access (Modulo) Sports Sussy (-25mm f/r)
Front Rubbing: No
Rear Rubbing: No
Comments: Saved what feels like about 4lbs (maybe more/less?) from the stock setup, don't have a scale to get an accurate weight savings, but definitely lighter by a good bit. Grip level has increased by a wide margin, which is to be expected comparing the stock Dunlops to the Neovas.
Will get better pictures later...
Old Feb 19, 2010 | 06:52 PM
  #825
cjung's Avatar
link to Fit build
Just wnted to give you guys the opp. to check out my fit, I dont have any personal pics but you can take a look through the link provided.
Customer Car: 2008 Honda Fit - HKS Turbocharger System... - Page 7 - ImportsNC Online Forums // Your Source for NC Import Scene
Old Feb 23, 2010 | 10:00 PM
  #826
mk donz's Avatar
new wheels
OZ FUTURA 17x8.5 17x10
Old Feb 24, 2010 | 12:25 AM
  #827
Fit4Trav's Avatar
^^More pictures ASAP
Old Feb 24, 2010 | 11:34 AM
  #828
mk donz's Avatar
^^ new picture
Old Feb 28, 2010 | 11:42 PM
  #829
jookybanana's Avatar
Wheel: Work Emotion CR-Kai
Offset: +42 front, +42 with 10mm spacer rear (so its +32)
Color: gunmetal
Tire: Falken FK-452
Size: 215/35/18 all around
Lowered?: yes
If Yes, What Setup?: HKS Hipermax S-Compact
Front Rubbing: No
Rear Rubbing: No
Comments: front fenders untouched, rear fenders are rolled flat, MXP lug nuts
Old Mar 2, 2010 | 12:46 AM
  #830
Old Mar 2, 2010 | 03:54 AM
  #831
ej96hatch's Avatar
Originally Posted by jookybanana
Looks good! What are the specs on the wheels/tires/drop, any rubbing issues?
Old Mar 2, 2010 | 08:48 AM
  #832
18x7.5 +42 front and +32 rear, 215/35/18 all around and lowered with hks coil-overs
i rolled the rear fenders, front fenders are untouched, no rubbing so far
Old Mar 2, 2010 | 03:11 PM
  #833
ivtechFit's Avatar
Can someone please post an 2010 Blue Sensation pearl with "White rims"?
looking to get an set, i wanna see what you guys got?
Old Mar 2, 2010 | 07:56 PM
  #834
Necos07's Avatar
G07WT by Rays in 17x7 +43 offset w/205/40/17 Toyo Extenza HP
Old Mar 2, 2010 | 09:46 PM
  #835
ivtechFit's Avatar
almost flush man. its your car 09 i can really tell?
Old Mar 3, 2010 | 02:15 AM
  #836
Fit4Trav's Avatar
Old Mar 3, 2010 | 02:19 AM
  #837
DreaMv's Avatar
looks dope as fkk trav. i like it.
Old Mar 3, 2010 | 08:18 AM
  #838
Necos07's Avatar
Are talking to me? Mine is an 07 & I have the spacers on order to get her as flush as possible
Old Mar 31, 2010 | 11:22 AM
  #839
red07's Avatar
An update on my shoes
Then: Momo Rev 17s
Racing Sparco N1 15s
Now:
Concept One Sinister
Old Apr 9, 2010 | 07:31 PM
  #840
coreyhall4's Avatar
my 2008 with 17-7 +42os 5zigen FN01R-C'c in gunmetal 205/40zr17 rubber
