Tenzo Type M 17 inch!
Tyler
I think the rims look hot. What are you running for suspension, springs or coilovers? I agree that the only way they are gonna look right is slammed.
all the 4x100 which it states it has will fit.
get those wheels. ahhh you might rub. more likely you will, but thats is such an easy fix. when you lower your car more, it will create camber, which pushes the wheels inward. so you might and might not have a problem.
and if you buy coilovers you can always lift it up. but i doubt you will be "low" on springs.
hmmmm.... so from the looks of your previous posts and your current ride/set up...can I safely assume you are hugely biased?
haahaa
your ride is sweet though!
....sorry...carry on...
haahaa
