Add offset/spacer to stock wheels?
Old Jan 15, 2011 | 09:17 PM
WhiskeySix's Avatar
Gotcha, thanks guys. So I want "4x100, 10mm, 2-piece, hub-centric spacers"?
Back to Google I go
(I can't be the first one without access to a press to put 10+ mm on. Anyone have a link to something that's known-good?)
Old Jan 15, 2011 | 09:29 PM
DiamondStarMonsters's Avatar
Back to Google I go
Old Jan 15, 2011 | 11:53 PM
grtpumpkin's Avatar
I don't think you will need to torch the hubs, they aren't really that hard to get out. Mine popped without a lot of pressure being put on them (I have a twelve ton shop press) You may even be able to get away with using a large punch and a five pound sledge hammer to drive them out. Of course you can also go the bolt on route, whichever makes you more comfortable.
Old Jan 20, 2011 | 10:28 AM
WhiskeySix's Avatar
Thinking bolt-on at this point. Thoughts on these? Say they're for a del-sol, but the specs look the same I think?
KGS Racing - 1992-1997 Honda Del Sol 15mm Wheel Spacer - At KGS Engineering
Brand New HubCentric Wheel Spacers
Price For 2pcs (1 Pair)
Width: 15mm BS
Bolt Pattern: 4X100
Thread Type: 12X1.5 LUG NUT
Center Bore: 56.1mm BORE
Old Jan 21, 2011 | 12:29 AM
Jodele's Avatar
Now you are up to 15-mm!? WTF...this is a bad idea getting worse...
Nice try...The Fit has 70.1-mm center bore...won't fit.
Old Jan 21, 2011 | 06:53 PM
grtpumpkin's Avatar
I don't know that a 15mm would work with stock wheels AND lowering. That would probably cause serious rubbing without a bumper tab-ectomy and some lip rolling just FYI.
Old Jan 21, 2011 | 10:08 PM
Perrenoud Fit's Avatar
Talking Before and after spacers
I have a GD3 and have 25mm out back and 15mm up front w/no problems and it's been a year +, on stock 15" sport rims.
and yes they have the lugs in them ichiban and I did it because the factory had the wheels pulled in too far! That or fatter tires and less MPG, not.
Old Jan 21, 2011 | 10:21 PM
Honda Fit (07-08) 1"
Please wait
Image not available
Item condition:NewCompatibility:
See compatible vehicles
Quantity:
More than 10 lots available (2 items per lot)
Please enter a quantity of $quantity$ or less
Please enter a quantity of 1 Purchases are limited to $quantity$ per buyer
Please enter a lower number
Please enter quantity of 1 or more
Price:US $49.99Buy It NowBuy It NowBuy It NowAdd to Watch list
Old Jan 21, 2011 | 10:39 PM
Looks sharp Mike!
Old Jan 21, 2011 | 11:23 PM
Thank-you Chris
Old Jan 22, 2011 | 06:18 PM
grtpumpkin's Avatar
It does look nice. But, you are at stock height correct? I'm just thinking that if OP wants to go lower as well he may have problems with rubbing. BTW, what tire size are you running? Looks like a 205-55 like me....
Old Jan 22, 2011 | 06:52 PM
  #32
Unhappy Don't do this if you'er lowering! no no no!
Thanks G.P.,
195/60/15 eagle gt
Ran mine about a month with stock shocks, no good
I added airshocks to MzFiT and the biggest reason was rubbing. And at the same time it raised the load capacity by 1.5k lbs. @ 120 psi. and it looks StUpId high . 40#'s is good though.
Old Jan 23, 2011 | 08:28 PM
  #33
WhiskeySix's Avatar
appreciate all the feedback guys... I'll definitely approach the spacer thing with caution. I'm going to get the springs installed first and then see what I'm dealing with.
At this point, I suspect I'll keep the front stock and consider adding a 5mm ring to the rears.
peace
Skimmer
Racing
17
Nov 25, 2015 07:06 PM
KCTitan
Jul 20, 2012 12:43 AM
bread bucket
Sep 15, 2008 05:15 PM
HONDAJUNKIE
Jun 16, 2008 11:19 AM
OJ Glove
Feb 20, 2008 09:50 PM
