Cruise switch fix
Old Mar 28, 2021 | 10:44 PM
rocksnap's Avatar
Cruise switch fix
The CRUISE CONTROL POWER switch, ON THE RIGHT SIDE OF THE STEERING WHEEL, is a known failure item. Not staying clicked, in the on position. But what to do about it, when it fails?
A new switch for my 11’ Sport with NAV, uses a $170 wiring harness that serves both the LEFT & RIGHT side steering wheel switches. If you can get by with just the right side harness, you will save $100.
An even cheaper & easier solution?
There is some wiggle room LEFT AND RIGHT, with the switch.. A lil gel superglue down either side of the switch, then depress & hold the switch. And wedge a very small item on the NON-glued side of the switch, till the glue has dried.
Of course you will never be able to switch the power off, but I never did anyhow.
You are welcome.
Old Oct 16, 2021 | 10:21 PM
pingels's Avatar
I just bought a Fit with this issue. How's the superglue fix holding up?
Mesa Mark
May 20, 2023 08:29 PM
ritholtz
Feb 4, 2015 09:16 PM
VtxBlueFit
Jul 14, 2013 03:29 AM
StormSurfer
Jul 25, 2011 02:05 PM
OhNineFIT
Sep 3, 2009 12:19 AM
