How would you solve rust under the antena base?
Old Jan 15, 2023 | 07:51 PM
atomicwrites's Avatar
So looks like previous owner had a bit of a cheapskate paint job on my 2017 Fit (lots of over spray, looks like nothing was disassembled only masked off), and I was noticing there's some rust forming under the antenna mount base. Would just putting a shark fin and sealant over it be a good way to mitigate? And if cleaning first will be necessary, does that mean sanding or will something like evaporust work and not damage the paint (they say it wont, but not sure for automotive use)?
Thanks.
Old Jan 15, 2023 | 07:52 PM
Oh, off topic but is there a way to make images not be massive like that?
Old Apr 15, 2023 | 02:35 AM
KelleyPhillips's Avatar
Can you please share the clear image.
Old Apr 16, 2023 | 12:25 PM
woof's Avatar
I would remove the antenna base to see what's underneath. Lightly sand loose rust off and then apply an anti-rust primer and then some top coat. Allow to fully dry and then remount whatever antenna base you want. You can't just seal the rust in and leave it as is. The rust will continue to eat away at the metal
Kdawgz
Apr 26, 2016 12:38 PM
luciusad2004
Jun 17, 2014 06:34 PM
Mainer82
Oct 17, 2011 03:27 PM
idlingmike
Jan 24, 2010 01:18 AM
DrKelso
Nov 20, 2008 03:22 PM
