Metalic rattle A/C
Old Jul 8, 2023 | 09:43 PM
Cliffsfit's Avatar
Metalic rattle A/C
2019 FIT, Automatic, 105,000 miles. When the car is idling with the AC on. Every time the fan engages there is a rattle. It seems like a metallic rattle. If I turn off the AC, the rattle goes away. AC is cold. Never hear it while underway. Stop at a lite, and It reappears. There are two fans that I can see. Is it possible one or both of the fans are going bad. Maybe a bearing? I'm not really a car guy so I appreciate any guidance. Thank you
Old Jul 15, 2023 | 11:44 PM
MTLian's Avatar
it is the bearing in your ac clutch.
Old Jul 16, 2023 | 07:10 AM
Cliffsfit's Avatar
Thanks very much for the reply. Is that a part that can be replaced or do I need to replace the entire A/C compressor? thank you
Old Jul 17, 2023 | 01:06 AM
MTLian's Avatar
Unfortunately, I don’t think Honda sells that bearing as one unit. It can totally be replaced, you don’t even need to remove the compressor. You do however need to get some kind of puller to remove the compressor clutch pulley. To do this, you must remove the serpentine belt which is a little tricky on the GD3. I ave some tips to make it easy though if you have a GD3 (first Gen).
they sell ac clutch kits but it would be a shame to scrap the whole clutch just for a bearing.
mxl180
Apr 10, 2017 10:12 PM
Jeff Jeffro Tompkins Sr.
Aug 11, 2016 10:58 AM
jjrbus
May 31, 2014 10:05 AM
ASTEIN
Jul 13, 2010 01:20 PM
stickyricebandit
Jul 22, 2008 08:41 PM
