Why is engine in ass backwards?
Old May 19, 2024 | 11:55 AM
nik danger's Avatar
Drive '12 Fit 5 MT.
Technical question: Why in the world did Hinda engineers put my motor in ass backwards? My son's 08' Civic 1.8L isn't in ass backwards.
Makes changing spark plugs/coils a bugger to access/replace.
Nik
Old May 20, 2024 | 12:22 PM
Hootie's Avatar
Originally Posted by nik danger
Drive '12 Fit 5 MT.
Nik
Did you actually mean, "Why is your cylinder head design reversed compared to the R18 in your son's Civic?" The engine and transmission position is the same otherwise.
It simply comes down the how the engineers designed the engine as well how it is packaged in the engine bay as well.
You DO have to keep in mind, that the first and second gen Fits have a significant difference in the front ends for US/Canada spec cars versus the rest of the global market. The shorter nose on the global cars requires Honda to package the engine bay even tighter than our long nose cars. Even then, it's not that bad to access. Changing spark plugs doesn't require cowl removal and can be done in 15 minutes or less. Even removing the airbbox assembly and upper intake manifold MIGHT add another 3 to 5 minutes to tear down to give you even more room to access the spark plugs and valvetran without removing the wiper cowl.
Following that, Honda could have given us the Dual Spark version the L15 their engines but instead the VTEC model we received. Those DSI cars actually run 8 spark plugs total (2 per cylinder) versus 4 spark plugs in comparison to the VTEC cars. Adding to that, those DSI engines are present state side but found in Hybrid models such as the first and second gen Insights as well as the 8th gen (your son's body style) and 9th gen Civic Hybrids as well.
Old May 21, 2024 | 08:50 AM
NWCH's Avatar
There is no such thing as designed backwards.
It's just an engine design. Most newer cars don't have easy access to the spark plugs in general.
Old May 21, 2024 | 05:54 PM
fujisawa's Avatar
Just go stand around behind the trunk. It'll all look a lot more normal from that angle.
Old May 22, 2024 | 09:10 AM
PK86's Avatar
That describes my Fiero exactly. When I go work on a different car, it suddenly seems backwards to me!
Old May 25, 2024 | 03:03 PM
nik danger's Avatar
I'm being pedantic: I did not ask why honda designed the FIT engine assbackwards, I asked why was the engine put in with the spark plugs/coilpacks facing rear as FitFreak poster, "Hootie", revised my question to reflect a space consideration by Honda engineering.
Old May 27, 2024 | 08:25 AM
screwtop's Avatar
Funnily enough, I've found that I can change all 8 coils and plugs on my JDM Fit's L13A engine without removing the cowl. It's a bit fiddly and requires some creative stacking/unstacking of extensions, but is surprisingly doable. I wonder if the L15's larger size makes for harder access.
Old May 29, 2024 | 01:27 PM
mobby_6kl's Avatar
Now that you say that, Honda should make a RWD Fit...
Kirbytrainnerd
Mar 25, 2023 10:26 AM
ansys
Sep 26, 2022 01:27 AM
DaytonaFit
Jun 27, 2018 06:24 PM
jcroucier
Aug 23, 2016 04:46 PM
zrkd51
Jun 4, 2015 06:15 PM
