Question for anyone that has lowered their Fit
Old Jul 29, 2024 | 01:59 PM
rick5070's Avatar
Okay I did a slight lower on my '09 to the tune of "1 1/2.
I did a proper job in using the correct springs and struts all the way around and I had to replace the exhaust due to rust from the pervious owner, so I installed a yonaka mild exhaust.
Everything seems to fit properly but I noticed that the exhaust hangs a bit lower than the car and since I put new wheels on it I am finding that will sometimes drag a tiny bit over speed bumps and the like.
Has anyone used different hangers that are shorter or has anyone had to solution for this?
Anything helpful would be welcome as this isn't a huge problem but its kind of annoying.
Thank you!
Old Jul 29, 2024 | 04:23 PM
Frenzal's Avatar
If you have room to move the exhaust a bit higher, you can use shorter hangers. But be sure to have enough room around, because the exhaust gets hot...
Old Jul 29, 2024 | 06:12 PM
rick5070's Avatar
Have you used them before or know which ones to order or from where? This is kinda what I was thinking!
Old Jul 30, 2024 | 12:33 PM
Frenzal's Avatar
I'va had to replace some on my 00 Civic, which was lowered. Just went to a auto part store and chose a shorter one!
Old Jul 30, 2024 | 08:37 PM
rick5070's Avatar
Perfect! Thank you! I will have to look into adjusting and trying some shorter hangers, I really dont need that much more clearance,
Hopipola
Jul 21, 2023 03:58 PM
kurisux92
Apr 10, 2016 06:38 PM
hogwylde
Feb 25, 2011 05:45 PM
pastafarian
Dec 17, 2007 04:06 PM
