Help Connecting AMP Controller *Amp Turn On Wire*
Old Nov 5, 2025 | 10:34 PM
FitDeezy's Avatar
Hey guys so i bought a chinese Aftermarket radio, i hooked up the amp and sub all correctly and the only thing im stuck on is the Amp turn On Wire,, ive trouble shooted to make sure the amp is working and i took a small wire and bridged it to the power and the remote and all works as it should. Also got another wire connected to the remote and straight to my radio
Amp Control Wire and sitll nothing,, dont have a multimeter but regardless with that second wire testing jsut shows that no/not enought power is going to the amp,, so now i need to wire it to another wire somewhere else,,
I read that you can plug to the ciggerete accs wire but its too tight and im not dealing with all that,, and idk what other wires or place to tap it in,,
In therory i just need something that turns on when ignition is on, and turns off whenever the key is unplugged
[img alt="this is basically how my wiring looks like more or less, and one has amp ctrl
as well a side note and please lmk while youre helping me, my rca cables from the amp to the radio i only ffound one rca that says Subwoofer, so i plugged the Red one *ONLY* in there leaving one of the RCA unplugged? is this fine, i mean it works and i havent had a issue whenever i was testing it,, i just dont know where else to plug the white rca"]https://cimg7.ibsrv.net/gimg/www.fitfreak.net-vbulletin/480x473/screenshot_2025_11_05_223631_6d6ecb1ce57603a4dd6f6 600255b8b950f57001c.png[/img]
this is basically how my wiring looks like more or less, and one has amp ctrl as well a side note and please lmk while youre helping me, my rca cables from the amp to the radio i only ffound one rca that says Subwoofer, so i plugged the Red one *ONLY* in there leaving one of the RCA unplugged? is this fine, i mean it works and i havent had a issue whenever i was testing it,, i just dont know where else to plug the white rca
any information would help thank you! i really want to get this done tommorow morning so if you know anything just lmk!
Old Nov 6, 2025 | 04:41 PM
FitDeezy's Avatar
ok as normal people would tap to something else that turns on with the ignitions is turned on,,
SIMPLE HOOK UP
theres diffrent fuses, 2 fuses ik that work
Fuse 17
Fuse 36 either one of these are acc's fuses and are not critical to the car if they blow,, use these, get a Wiretap Fuse Kit ** YOU WILL NEED A LOW PROFIL MINI FUSE!**
and its simple to wire and set up,, sub bumping in the fit :3
ieandro
Fit I.C.E.
Jun 17, 2019 01:32 AM
GoShogun
May 25, 2018 01:54 AM
Perrenoud Fit
Dec 18, 2010 01:55 AM
Perrenoud Fit
Oct 12, 2010 11:52 PM
itfits12
Dec 18, 2007 09:35 PM
