dim headlite
Old Nov 3, 2025 | 11:42 PM
scdrtramp's Avatar
Cool dim headlite
Hello all. haven't had my Fit but about a year. When I bought it the pass side headlight was dim, on DRL's or headlights, and both beams. I got top looking at it and can see that the pigtail for the headlite was changed. it was spiced it the harness. all the connections are good. I think it has to be a ground problem, Has anyone ever seen this before. thanks
Old Nov 4, 2025 | 05:29 AM
Frenzal's Avatar
Might just be that the bulb is different?
Old Nov 4, 2025 | 06:55 PM
scdrtramp's Avatar
new bulbs, and new headlights
Old Nov 4, 2025 | 08:13 PM
bobski's Avatar
Year and trim?
Old Nov 5, 2025 | 11:11 AM
scdrtramp's Avatar
2011 sport
Old Nov 5, 2025 | 12:47 PM
bobski's Avatar
High and low beam share a ground wire from the bulb to the chassis (ground point G201):
G201 looks to be behind the front bumper cover. Number 6:
Though if someone replaced the headlight connector, I would unwrap their ground wire splice to verify there's more than un-stripped wire and a glob of solder in there.
Old Nov 7, 2025 | 12:42 PM
scdrtramp's Avatar
Thank you for the information. I didn't know where to look for the ground. I did check the joint where they replaced the pigtail, it was a crimp fitting so I soldered the joint already. I'll check out the grounds and get back to ya. thanks again.
oman
Dec 21, 2017 10:10 PM
bach
Jan 15, 2016 02:24 PM
Ciggy
Apr 14, 2010 10:25 AM
FELIXY69
Jan 7, 2008 03:42 PM
FikseRxSeven
Aug 19, 2006 09:45 AM
