depo tail help QUICK!
Old May 23, 2008 | 11:17 AM
c_mack9's Avatar
i need help. i got some depo tails and i figured out the wiring and fitment and all the normal problems BUT i have a new one. the socket hole on the bottom where the reverse light should go in doesnt match the oem one. does depo normally provide a socket that plugs into the oem harness? mine came in a plain unmarked box wrapped in plastic with peanuts, nothing else. wtf?
Old May 23, 2008 | 04:44 PM
Kyle is raaddd's Avatar
Master FitFaker. CHEA!
is there something like a adapter you can get for it?
try to search for the tail light and find all the things that come with it.
i'm not really sure
Old May 23, 2008 | 04:46 PM
George02's Avatar
yea but its not worth it. it will fit in there but you have to wiggle it around to get in there
Old May 23, 2008 | 06:05 PM
c_mack9's Avatar
no its hard to explain, the holes in the taillight dont match up with the tabs on the socket. there is no way it could possibly fit. there is 4 tabs in the hole and 3 tabs on the socket.
Old May 23, 2008 | 06:09 PM
JDMchris.com's Avatar
I run THIS
You can get it to fit. It will secure in when you twist it crooked, but it will stay and wont fall out.
Old May 23, 2008 | 11:31 PM
c_mack9's Avatar
ok thanks a lot. i apppreciate it. i had never seen this problem posted anywhere. ill put them in tomorrow.
Old May 23, 2008 | 11:36 PM
billmus86's Avatar
My Lips Bigger!
its bc that hole is designed for the rev lights, not blinkers,
or vice versa
billmus86's Avatar
My Lips Bigger!
ehh.. i dont know
nm
Old May 23, 2008 | 11:48 PM
c_mack9's Avatar
case closed. thanks for the help fellas.
Old May 23, 2008 | 11:56 PM
George02's Avatar
youre welcome, and this was on plenty of led taillight threads
Old May 24, 2008 | 12:20 AM
c_mack9's Avatar
dude honestly i swear to you i searched and never found it. i even searched on HT too. i was searching the depo threads cause i didnt know it was a JDM replica problem, i thought it was a DEPO problem.
Old May 24, 2008 | 02:24 AM
well i'm glad you got it worked out then!
xonexlifex
Nov 4, 2009 02:10 AM
09blackfit
Sep 4, 2009 08:26 AM
herbalteebag
Jun 5, 2009 04:34 PM
chinkyy
14
Jan 24, 2009 11:49 AM
DrKelso
Aug 28, 2008 10:45 AM
